so i have about 400 miles on her now since i did extensive carb re build valve adj. all fluids etc.etc.
took it for a good hard thrashing afew days ago...shifted around 7000 to 7500
held it WFO for a god rip a couple times...only pulled up to 7400 in top cog at wide open
now it doesnt seem to make much power till around 4000 then she will pull pretty good...
have not done the petcocks or octo.yet...seems kinda sluggish down low..also kinda sounds like there is an exaust leak
but i only really hear it well with my helmet on...tightened the header bolts,a couple loose but not bad
any thoughts? mabey i ran her to hard?
. The only change made between the two associated with the pic-up wires was the loom holder location which gave the later 4RO wires a bit more free play, but still no help for the constant movement of the vacuum advance plate.
