Valve stem seals
  • xs650man
    • Feb 2013
    • 90
    • Christchurch, New Zealand
    Valve stem seals
    Has anyone changed valve stem seals and springs without taking the head off ? I've read about guys doing it on small block chevys using either compressed air or soft rope inserted in the plug hole and the piston carefully raised to support the valve. Not sure how you would compress the spring tho, some sort of lever arrangement maybe ?
    80 SG
    93 ST1100 Honda
    66 split screen VW bus
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Believe me, no matter if you figure it all out, it will be a lot easier to pull the head and then you can be assured it is done right. Save you a bunch of busted knuckles too!
    Mike Giroir
    79 XS-1100 Special
      And I was going to add that IF there is that much WEAR to the point the seals are leaking, then you've probably got lots of junk/corrosion or such on the valve shafts....as well as posssibly burned oil in the valve face/seat junction. So...will be a good time to also LAP the valves/seats while you've got it apart to help freshen up the top end sealing properties. Perhaps even decarbonize the top of the pistons and the combustion chamber as well.
      • MPittma100
        • Aug 2011
        • 2359
        Springs
        Buy some new springs and seals. Take them, the head, and the camshafts to a reputable machine shop.
        The shop can clean (media blast) the head and valves. They will reface the seats and valves. They will also adjust all lashes so you won't have to. You may or may not end up needing some new valves.
        It is worth it to have this done.
        My 2 cents.
        Mike
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
        • The Lorax
          • Jun 2005
          • 1048
          • Riverside, OH
          I have done it on a small block Chevy, very easy, but yes, you compress the spring with a lever. The fulcrum point is the rocker arm stud. As there isn't one on an XS, that's not going to fly. If I thought about it long enough, I could probably come up with a way to do it on the XS, but there doesn't seem to be a real point to doing it that way. May as well pull the head and do the seats, seals, and valve clearances all at the same time without worry of dropping a valve into the cylinder or buggering something else up. Take the time to do the job right, you will thank yourself later. Have a nice day and ride safe
          I am the Lorax, I speak for the Trees
          '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
          '79 XS1100 F R (IL Barrachino)
          '00 Suzuki Intruder 1400 (La Soccola)
          '77 KZ400s (La Putana)
          • jwhughes3
            • 2798
            • Home of the Alamo
            My 2 cents.
            Mike
            What Mike said. Machine shops are there for a good reason.
            John
            '81 XS1100H - "Enterprise"
              My 2 cents.
              Mike
