Left Side Cover Question
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Hello All
    I am finished with my bike build and went to put on the left side cover and it doesn't fit. I assume there is supposed to be a place on the frame to lock the side cover in, like on the right side, but there isn't. Can someone take a pic of their left side cover mounting hole and post it? It should mount just below the battery, but there is no mounting hole. Perhaps it is on a part I am not using. I know this sounds silly but nevertheless I still need the help.
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    The left side has a lock like this.
    You can see it in the lower right hand corner of this photo.
    Ride safe,
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
      • 8891
      This latch mechanism bolts to the frame below the battery box....
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        I am such an idiot. I forgot to add the latch. Thanks for the pics. I really appreciate it. I took the bike out for the first time yesterday. WOW it is fun. I did get some 2 gear slip. I thought that I undercut the gears enough for it not to slip. I guess I was wrong. I just finished with the bike. It took three years. I would really hate to have to take the trans apart again.
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
