Hey guys,
I'm stumped on fixing my front brakes. Last year I had underwhelming brake power in addition to an alarming rattle, so I decided to at least change the pads this spring and install the special retainer clips.
1. Got the pads out and got the classic shock that they're slanted. Was relieved to find out that's normal
2. But then I could not for the life of me push back the piston
3. So I removed calipers and disassembled, cleaned, and knocked down a couple small burrs that were making the piston hard to move. By the end of that process I was able to reassemble and push the piston back manually.
4. I went to reinstall with the new pads and did not have the clearance to put the new pads in. It was as if the new pads were too big to fit on the rotor and in the caliper. The issue appears to be alignment related. I've read about alignment issues, but not sure how that works. This is my first major dilemma. I tried the old, worn down pads and they fit, but just barely. Lots of rubbing. So first big question is:
What tricks do I need to know to properly reattach the caliper with the new pads? I read a post that discussed the height problem with the washer. My problem is left to right alignment though. In order to get the mounting bolt on I have to push the caliper to one side which then creates the issue of fitting both pads.
Next issue is bleeding the brakes. I tried manually to no avail. Then I bought a pneumatic bleeder and got the same abysmal results. What are the symptoms of a clogged and/or poorly functioning brake master cylinder?
