Hey Guys,
I know that there are a number of smart guys here with a lot of experience so once again I’m going to call on you.
I am trying to tune my 82 XJ. Have done a good cleaning, re-synced the carbs a couple of times, each time with varied success, mostly improvements.
Engine wants to bog when the throttle is opened. I stretched the springs above the diaphragm piston making them about an inch longer. That seemed to help lessen the bogginess. If I open the throttle slowly the RPM will rise to 5-6 grand easy. Close the throttle completely, and the RPM drops to 3,000 and stays there. The linkage is not sticking, it comes back too and seats on the adjustment screw completely. The RPM will not drop to idle unless I put a thumb and a finger over the idle air jets inside the intake throat on two carbs, any two, (Air cleaner is off at this point.) After that it drops back down to 1000 rpm, and will stay there until you again open the throttle. Once again it revs and will not drop below 3 grand.
I’ve been scratching my head on this one. If it was a vacuum leak, it would be there all the time, or maybe only when hot. No signs of a vacuum leak. I have used the propane torch trick. The only time the engine reacts is when I point it down the carb intakes.
Any help here would be greatly appreciated. Thanks, Dale
. That would work the same as having pin-holes in diaphrams
. Since it was a guesstimation as to how much, you may or may not get a couple of coils to give up enough to get them back to original 'resting' height, whatever that was. Someone here may have a set of the later carbs apart and give you that measurement.
) When you cleaned those carbs did you make sure those 3 little holes in the top of the venturi just behind the idle mixture orifice and the top of the butterfly were clean and clear?
