Swapped triple trees?
  • Orange4
    • Sep 2013
    • 398
    • Maple Ridge, B.C., Canada
    Hi
    I noticed that the triples are different between my '78 and '79
    Are these stock or were they swapped and if they were swapped what are they? Both sets of forks are bottom mount axle.
    On my '78
    On my '79
    Living to EXcess.
    1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
    It is hard to tell them apart from the upper trees, at least for me anyway. The lower trees are easily identifiable. The lower tree with the tube pinch bolts facing forward are for the Standard fork which is the type that sits atop the axle. The Special lower tree for the forks with the leading axle has it's tube pinch bolts facing to the side. HTH
    • Orange4
      • Sep 2013
      • 398
      Thanks. Mystery solved.
      The '79F has a special triple tree with standard forks:
      Now the next question is how will this affect the handling since the bike still has the standard forks. Should I get the standard tree back on there?
      Living to EXcess.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Hi, Orange -
        It will affect the steering geometry ... someone CMIIW, but my understanding of this situation is:
        Special triple trees with Standard forks will cause the fork tubes to be moved back, which will increase the trail, thus causing the steering to be heavier.
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
        • Orange4
          • Sep 2013
          • 398
          Hmmm
          You have made me think about this. Another way of explaining my case is the special forks would move the wheel forward in relation to the rake angle, reducing trail compared with using standard forks.
          So my set up has more trail than a stock special and the most trail possible with stock parts all else equal.
          Then there is the fork offset which is greater on standard trees. Greater fork offset reduces trail right?
          So Standard trees with standard forks has less trail than special trees with standard forks
          And standard trees with special forks would give the least trail.
          The last question is the offset of the different trees.
          Simplest way to put this:
          Most trail: Special trees with standard forks
          Standard trail: Stock
          Least trail: Standard trees with special forks
          Am I on the right path here?
          Living to EXcess.
          • Prisoner6
            • Aug 2013
            • 1184
            • Phoenix, AZ
            First: Yes, Special TT's with Standard forks increases trail compared to a stock Special.
            Second: Yes, Standard TT's with Standard forks = less trail than Special TT's with Standard forks.
            Third: Yes, all else being equal, Standard TT's with Special forks = the least trail.
            Fourth: Sounds like you're on the right track ... I'm sure you know this already, but stock Specials and stock Standards have identical rake/trail specs.
            So when you start swapping them around, it affects the steering geometry.
            Less trail = Lighter steering
            More trail = Heavier steering
            At least with your set-up (Special TT's with Standard forks), you'll get the benefit of increased upper body strength!!
            Hope that helps ...
            Marco
            1979 Honda CBX
            WE MISS YOU, DON
            • MPittma100
              • Aug 2011
              • 2359
              Forks
              You should definitely keep the forks and triple trees matched and not mixed.
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
              • Orange4
                • Sep 2013
                • 398
                Thanks for walking me through that.
                Living to EXcess.
                • Prisoner6
                  • Aug 2013
                  • 1184
                  • Phoenix, AZ
                  You're welcome, O ...
                  FWIW, I agree with Mike that the best option is not to swap TT's and forks around between Standards and Specials.
                  But that's just my opinion ...
                  Marco
                  1979 Honda CBX
                  WE MISS YOU, DON
                  • Orange4
                    • Sep 2013
                    • 398
                    PO did the swap. Now that I know, I'll be going back to stock. He had a fork mounted fairing on it so maybe he wanted more stability at speed. Just a guess.
                    Now I can look for a stock unit or maybe I'll take the opportunity to do an XJ fork swap since its on the project bike.
                    Living to EXcess.
                    • Prisoner6
                      • Aug 2013
                      • 1184
                      • Phoenix, AZ
                      I think that's a good idea, Orange. I was chewing on this issue a little bit more, and wanted to add a short P.S.
                      Yamaha must have chosen to set up our bikes with the rake/trail numbers they did for a reason.
                      They were probably trying to strike the best compromise between styling, handling, stability, ease of steering, etc.
                      Swapping the components around could create some awkward handling moments, or more seriously, a potentially dangerous situation. JAT
                      I know some have done it and been OK (I think Fred did it to lighten the steering for his sidecar rig), but I can't imagine ever doing it myself.
                      Marco
                      1979 Honda CBX
                      WE MISS YOU, DON
