Bigger Is Better
The early motors had 9.25 to 1 compression and the late ones had 9 to 1.
The 74 mm Wiseco piston creates more compression with essentially the same dome volumn as the stock late piston because it is larger and has more swept volumn and because it is larger in diameter it's dome is shorter than the late stock piston even while both have 6cc's of dome volumn.
To make a long story short, a set of 74 mm Wiseco's in a early motor will make about 10.2 compression as advertised by Wiseco however in a late motor they will only make about 9.5 if everything is stock (uncut).
