how to change speedometer cable on 1979 yamaha xs 1100 special motorcycle
  • dolphans1
    • Mar 2013
    • 168
    • Orlando, Fla.
    How to change speedometer cable on 1979 yamaha xs 1100 special motorcycle??
    Just ordered a new speedometer cable for my 1979 Yamaha XS 1100 Special motorcycle and the one I received appears to be different than the one on my bike. Both ends of the new one look identical, can anyone clarify if there is something I am missing or not seeing correctly?
    79 SF
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Check the threads between old cable and new. Or just try putting it on the speedo drive or the speedo
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      Sounds like you ordered (or at least were shipped) a standard Speedo cable.
        • 9980
        DAMMIT! I told you to make sure you got one for a special because the standard cable is completely different.
        Did you order it from ebay?
        • dolphans1
          • Mar 2013
          • 168
          • Orlando, Fla.
          Yup, the 1979 Speedometer cable for an XS 1100 vs an XS 1100SF are definitely different.
          Thanks.
          79 SF
            • 9980
            Oops.. I thought I had discussed the speedometer and the cable with you recently. Apparently it was someone else.
            My bad.
            • jwhughes3
              • 2798
              • Home of the Alamo
              Please post instructions for how to change it without stopping.
              Thanks!
              John
              '81 XS1100H - "Enterprise"
                • 9980
                Easy. just adjust the flux capacitor to infinite negative and disengage the warp drive so the antimatter isn't disrupted and step into the time space continuum and the bike will seem to be frozen in the worm hole and it'll be a snap.
                Don't forget your dead blow hammer and rectangular drive screwdriver or you will have wasted someone elses time.
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  Thanks!
                  John
                  You might have an accident
                  Changing it on the move would more than likely require 3 people, 2 motorcycles and a side car
                  Stop the bike first and on center or side stand (center would make it easier) take the old cable off top or bottom, follow the old cable route with new cable, take off the other end and connect the new cable. Bob's your uncle
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                  • dolphans1
                    • Mar 2013
                    • 168
                    • Orlando, Fla.
                    My bad.
                    No problem, but there's this round gear gizmo attached to the bottom of the cable, that attaches to the wheel hub, what's the easiest way to remove this part?
                    What usually fails, the cable or that gear?
                    Thanks,
                    d-1
                    79 SF
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Speedo
                      Thanks,
                      d-1
                      "Usually" neither one fails. The speedo drive is driven by the rotation of the front wheel via a pawl in the hub. The drive itself has two gears in it. Clean and add new grease to the drive and to the speedo cable.
                      It is necessary to remove the front wheel to do this and you should check the wheel bearings and seals while you are in there. Parts are readily available. This is an easy job to do.
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                        • 9980
                        Thanks,
                        d-1
                        It's USUALLY the speedometer that goes bad first.
                          Would normally think so, but the cable wadded up a year after I bought bike new. Made up a new one at work with the square stomping die and tinned both ends with solder. Doubtful for but a few here that have seen or done this. Actually still have many feet of cable left, but has worked fine even to this day(lubed new cable with Sioux air gun grease before sliding in housing. Speedo itself is still original and gps's dead-on accurate with 82,180 on the clock...
                            • 9980
                            Yeah, I've had 1 cable go bad but I've been through 8 or 10 speedometers.
                            When the cable broke I got one of those universal kits from the auto parts house. It worked fine for a while but it only lasted a short time so I put a new one on. A new cable isn't but $10 or $15.
                            • Meista007
                              • Feb 2003
                              • 107
                              • Ohio
                              I've had one cable go and it was because it got crushed by the triple tree due to poor routing.
                              I was surprised how long it lasted before it went while being open to the elements.
