Unlocking the side cover/no key
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Anyone know of a way to unlock the side cover lock without a key ?
    Bought an 80 or 81 parts bike no keys or title.
    Got real lucky, in my stash of keys the very 1st one I tried worked in the gas cap and the ign., would not unlock the helmet lock or side cover.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • Bartman
    • May 2012
    • 200
    • Jefferson, Georgia
    I had to spray cleaning lube into the lock several times and finally got the side cover lock to release. You may not need to push the key all the way home before turning. I was afraid of breaking my only key too but finally got lucky. Hopefully your one key will work for all locks after lubricanting them good.
    79 XS11
      Key does NOT go in tumbler assembly but just a little ways to turn and release. Spray a bunch of WD or similar in there and keep working it back and forth a little to release those tumblers.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        I think I found a way, maybe ? Took the helmet lock apart and found the key would work IT if it was 1/16" longer.
        Remember this is a key I found in my stash and it was for a 1975 XS650 not for this 80/81 XS11.
        Going to the locksmith Mon., want to get that cover off not breaking it !
        I have tried not putting it in all the way,,,, that's what she said and still PG ?
        76 XS650 C ROADSTER
        80 XS 1100 SG
        • red bandit
          • 957
          • central michigan
          I know the key is supposed to work either way. Mine only works one way. Try turning the key over 180 degrees.
          79 SF parts bike.
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            It may be that the po had swapped out the gas and ignition locks, so the helmet and sidecover locks may be different. JAT
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Took the side cover lock apart and it seems if the key was just a tad longer it would work the helmet lock.
              Monday going to Whitlows, (they cut this key for my 75 XS650) and get another key cut just a tad deeper/longer.
              Still this may not help with the side cover lock ?
              So is there any way to remove the side cover and lock together or reach in there and release the lock ?
              76 XS650 C ROADSTER
              80 XS 1100 SG
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                In the very bottom of the lock assembly, directly under the lock tab there is a drain hole. If you take a small allen wrench (1/16" or so), you can stick it in that hole and pry the lock tab back. That should release the side cover tab from the lock.
                Ride safe,
                Larry
                82 XJ1100
                80 XS1100G (Project bike)
                64 Yamaha YA-6
                77 Suzuki TS-185
                  Just take the tumblers out of the cylinder and then as long as the key goes in the lock (or a screwdriver for that matter) you can turn the cylinder to unlock it.
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    Took the side cover off the LH and checked to see how the lock worked.
                    Tried the small allen wrench but could not get it to unlock.
                    Bent a small screw driver, got between the latch and the side cover hook, it came open so easily I could not believe it, had to try it a couple more times.
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
