1 check batter OK 12volt voltage drop to about 3 or 4 volt when starter is engage
2 turn moter with wrench on crank turn fine
3 pull starter clean and test out stater and rotor coil with vom test check out fine
4 bench test starter pull 15-25 amps
5 reinstall starter motor turn over slowly
6 remove wire from solenoid use small car batter to starter motor turn over slowly
7 put kick starter on use hand to turn over motor move fine
8 remove spark plug motor turn over fine with starter
9 put spark plug back in motor turn over slowly
do I have a bad starter (flying short) no torque under presser
