Headlight Mount Tube Diameter
  • Meista007
    • Feb 2003
    • 107
    • Ohio
    I'm looking into some different turn signal mounting options and wanted to know if anyone know the diameter of the tubes on the headlight mount? I believe (from reading on the site) that the fork tubes are 37mm but I would like to know the size of the tubes that slide over them to hold the headlight.
    79 XS1100 Special
    I checked one and it is 39MM ID.
    • Meista007
      • Feb 2003
      • 107
      • Ohio
      Do you think a 39mm turn signal clamp would work or would I need to go larger?
      Just asking because if I can order something before I go home to check I will get it sooner and I want this bike done ASAP!
        The OD of that tube is 42MM so if you are clamping over that tube somehow, yes I would go larger than the ID dimension of 39MM.
