anyone have a good method to cleaning up tarnished aluminum?
  • bikerdave79
    • Apr 2014
    • 45
    • Wilkes-Barre, PA
    I know the aluminum foil trick for the chrome but does anyone have any tricks for cleaning up dull oxidized aluminum motor parts? I've been using metal polish and elbow grease but its tedious as hell and doesn't work all that great. Any tricks or products anyone has had good luck with??
    79 XS eleven special
    Grey Scotch-Brite pads helps get the first layer taken care of and then it is all in the elbow grease....
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Scroll down threw Forums to Maintenace to Finish and Steve put out a how to that is as easy as it gets for a quality job. One thing that you should not do is use any steel wool to polish off corrosion as it embeds in the finish and rusts quick.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • bikerdave79
        • Apr 2014
        • 45
        • Wilkes-Barre, PA
        I am using scotch bright pads and soft brass wire wheels on a dremel to get into tight spots. Working great to remove the oxidation but having trouble getting a bright finish. I'll check it out
        • bikerdave79
          • Apr 2014
          • 45
          • Wilkes-Barre, PA
          I'm pretty much doing everything he says. I think I just need to keep at it.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            The prettier it looks the faster it gets ugly, unless you coat it or wax/never dull it often. You can get them to look like chrome if you want a show bike but if you want a rider the chrome like gloss goes away real fast.
            I can tell you how I did it and why I won't do it anymore, if you interested ?
            76 XS650 C ROADSTER
            80 XS650 G Special II
            https://ibb.co/album/icbGgF
            80 XS 1100 SG
            81 XS 1100LH/SH DARKHORSE
            https://tinyurl.com/k6nzvtw
            AKA; Don'e, UD, Unca Don'e
            • bikerdave79
              • Apr 2014
              • 45
              • Wilkes-Barre, PA
              Doesn't need to shine like chrome but the bike sat for 7 years. It was a family friends who got sick and can no longer ride. he basically gave it to me because I have the ability and good health to restore and ride it. His hopes were that could restore it to its former glory. It was his prized possession. I plan to ride it quite a bit, it doesn't need to be a show bike but I'd like to get it back to as close to original as possible to make an old man smile.
                I would say if you aren't looking for a lot of work and plan to ride it, then just use the scotch brite pads and maybe a little work with some buffing compoud and call it good.
                Maybe clear coat it to make it last lo get to. Can't clear coat it if it is too shiny since you won't have anywhere for the clear to stick.
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  In cleaning up the chrome foil picks up little bits of rust or what ever and ends up putting tiny scratches in the chrome. If the chrome is rough anyway this most likely won't matter and will make the chrome look better than it does with a rusty finish.
                  As far as aluminum my dad was a chef and he used brillo, soapy steel wool on his pans. No need for Teflon as I saw him slide and flip eggs in the pan that he polished with Brillo. Not a brite shine but surely a slippery one.
                  Try different types of abrasives, even stainless steel wool until you find the look you want.
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                    Au contraire! Glisten PC will stick to the shiniest aluminum. The metal prep will cut the shine down very slightly. I have a bike with this stuff on the fork legs. It is still crystal clear after 15 years. I recommend spray application. This stuff is once and for always!
                    Lower forks with 15 year old Glisten PC
                    Same bike, same coating years earlier.
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      Never heard of Glisten PC before. Does it come in pints/quarts/cans ? Did you do the side covers on the engine too ? BEAUTIFUL !!!!!
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                        Done,
                        It comes in pints, quarts, or gallons. Click on the blue letters in my last post. It's expensive, but it does what they say it does. Mine is crystal clear after a lot of years. In the photos, only the lower fork tubes are done. The rest, I have to work at.
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          As you may have found out by now, a lot of the surface of the engine is painted, and a real pain to get the paint off. The wheels, on the other hand have bare aluminum surfaces.
                          Air Conditioning service men use an acid product to clean the condensing coils on A/C units, and I use it to clean aluminum surfaces that are corroded. Brush on, let work, rinse well. It leaves a matte finish, but it is clean metal. Just don't let it dry on the metal. Another clear coat is Sharkhide, used by the AirStream trailer guys, and boatmen on the PNW coast. About the same price as the Glisten PC, but is a one part coating.
                          CZ
                            Sharkhide, I believe leaves a brighter surface than Glisten PC. The Sharkhide is temporary. Glisten PC is permanent.
                            • Dylano*
                              • Apr 2014
                              • 202
                              • San Luis Obispo, CA.
                              Well, I'm not sure how it's going to work yet, but I just got a sand blasting canister. (I have a media cabinet, but this is different) it basically looks like a silver can, about a pint big, with a handle, trigger and nozzle. Fill with your favorite media, connect air compressor and blast! I'm going to use fine beach sand I think. I'll let you know how it goes. Scrubbing with engine degreaser only goes so far.
                              Have:
                              1994 FZR600
                              1982 XJ1100
                              Had:
                              1996 YZF600R
                              2001 Honda xr125
                              Suzuki race 80
                              Honda PW 50
                              Etc.
                              Getting:
                              1977 DT400
