Working on getting the 78E back on the road. The engine is from a parts bike (79SF) good compression 150 across all four. Bike will start when I jump the terminals on the solenoid. (I do need to get some mufflers straight pipes are too loud )
I am using XJ1100 right hand controls and the start button is not working (it did work on the XJ) Could the problem with this be that the XJ has a ground wire coming from the control were the XS is grounded through the handle bars?
The other issue is the headlight does not come on. I'm still tracking this one down. Could be anything from fuse, burned out bulb, lighting module under the tank to just bad wiring. The PO took out the original fuse box and put in line blade type fuses. This all worked for two years until I put a hole in the #3 piston, and sitting for the last year I have used parts to keep/get other bikes up and running now I'm kicking my self for it.
