Headlight Question
  • Headlight Question
    Hello All
    I have a question about my headlight. I installed a LED Headlight from TrukLite. It looks great, however when start the bike the low beam and high beam light up. The switch does not turn off the high beam. However, when the bike is not running the headlight works as intended, with low and high. What do you think the problem is. Could it be the reserve light relay has gone bad? Or do you think it has something to do with the low draw LED? Thanks
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    I'd say either bad wiring within the headlight bucket, or bad RLU.
      You've got the plug shorted somehow. Sounds kinda like you have the low beam and high beam plugs backwards.
        I will check those things. But why would it work correctly when the bike is not running?
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
          Ian
          How does your headlight work? I would think mine would work the same as yours. The strange thing is it works as intended when the bike isn't running. As soon as I start the bike the high beam comes on and stays on.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            I was thinking. If the LED draws less power perhaps my problem is that the RLU thinks my low beam is blown thus switching to the high beam. So perhaps I need to bypass the RLU. What do you all think.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
              Off the top of my head, Rev, unless you do some modifications to add resistance to the headlight circuit the RLU doesn't play well with anything except incandescent lamps.
              Adding resistance to fool the RLU kind of defeats the purpose of putting in the high-tech low-current lighting so bypass the RLU and run the headlight straight from the Blue/Black wire after the Headlight Relay. If that fixes the problem then you can decide what to do from there.
                I would think this is the answer. Ditch the RLU.
                  Hey Rev- Yes, my headlight works fine. I believe my RLU is bypassed.
                    Wiring Bypass:
                    Reserve Lighting Unit: Unplug unit and connect blu/blk and blu/yel together at the harness plug.
                    2H7 (79)
                    3H3
                      Originally posted by bikerphil View Post
                      Wiring Bypass:
                      This sounds like the way to go.
                      Over the years I've only had 1 bike that the low or was it high beam (does not matter) burned out, at night. The light that was emitted by the alternate filament was not enough to see the road, so instantly I switched the switch gear control to the to the light that was just glowing and on it came.
                      This was a situation that could have been real bad if I had been running the curves out in the sticks on the mountain !!!!!
                      That RLU is only there so you won't be ticketed for not having any light on, not to light your way.
                      What say you all ?
                      76 XS650 C ROADSTER
                      80 XS650 G Special II
                      https://ibb.co/album/icbGgF
                      80 XS 1100 SG
                      81 XS 1100LH/SH DARKHORSE
                      https://tinyurl.com/k6nzvtw
                      AKA; Don'e, UD, Unca Don'e
                        Kawasaki put a RLD (Reserve Lighting Device) on my '81 KZ750 and the automatic headlight filament switcher thing saved my butt when I lived up in Oakhurst. Almost everyone lives off the paved road, third pine tree on the right, that kind of thing and riding off-road dramatically shortens the life of the sealed beam halogen headlight. You know it's going to fail, you just don't know when.
                        Now, having dated Murphy's daughter in High School he's never forgotten me so, naturally, the high beam winked out as I was tooling around Bass Lake one night at my usual safe and sane rate of speed on a narrow, twisty, two lane road going around the moonlit lake and the low beam instantly switched on.
                        The important part is that I stayed out of the lake that night so some fisherman didn't snag his hook on me or the bike the next day.
                        RLU: it's what's for dinner instead of you!
                        • #13
                          Head light "out" but no RLU indicator or low beam on my '81
                          As I read this thread, I'm wondering what might be going on with my bike. The headlight just stopped all together, (no warning light that I'm told would come on from RLU - and no low beam either).
                          I check resistance on the bulb and it seems fine. I guess next test is to see if it's getting volts.
                          Any initial thoughts here are greatly appreciated. Thank you.
                          Jay
                          • #14
                            Someone may have bypassed the RLU, it is located under the fuel tank just in front of the voltage regulator. The RLU may also be bad. Have you checked the headlight fuse?
                            2H7 (79)
                            3H3
                            • #15
                              Thanks, I will check.
