This is for stock replacements. You don't want to go over 5K ohms, you can go less but that can cause electrical interference with other devices (like phones, GPS, radios, etc) so keep that in mind. All four should be the same value.
Elevation
This is for stock replacements. You don't want to go over 5K ohms, you can go less but that can cause electrical interference with other devices (like phones, GPS, radios, etc) so keep that in mind. All four should be the same value.Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
I believe if the first option is no go(store doesn't carry those) you can buy non-resistor caps, and resistor spark plugs...the only reason for additional resistance is controlling radio frequency interference....Nick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
I got 4 NGK 5k ohm caps for $18 and change (discounted 'cause I'm a geezer). Just waiting on coils now.
Gunnery Sergeant, USMC (Retired), (A gung ho, lifer, Devil Dog) Semper Fidelis
XS1100E, 11.5" XV1100 shocks, "no name" 4 into 2 headers and turn out mufflers, stock air box, 140 mains, spade type fuse block, volt meter, LED conversion on running/turn/brake/tail lights, aux front driving and running light bar, 850 FD swap, Chrysler electronic VR. Ugly as a monkey's butt - runs like a scalded ape (WHEN IT RUNS
)Comment
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
