what is the advantage of not using the vacuum assist to pet cock?
makes it manual?
only works in prime?
do I run two vacuum lines from carb boots ? 1 and 4 or 2 and 3 ?
i heard i can file the nub off the backing plate and be able to turn shut off in the up position creating an off position.
what is the best way to go about this. i would like to have on and a reserve.
would i be correct in saying if i dont use vacuum, then prime is on and ...on and reserve is off?
makes it manual?
