cylinder
  • teck_mountain
    • Aug 2003
    • 128
    • Red Deer, Alberta, Canada
    cylinder
    Hello and help
    I'm attempting to put my cylinder back on and I am have a $&^% of a time. I replaced the pistons and rings to one size over Std. I did get the Cylinder on but I could not rotate the pistons to the T postion. Just got stuck? Ended up breaking a ring. *&^%^&%$ But the cylinders are jammed. Any idea?
    1979 xs1100 special
    Tim Lowe
    "Teck"
    1979 xs1100 Special
  • DEmily
    • Jun 2003
    • 220
    • Kansas City, MO.
    Hey Teck,
    Did you install one size over pistons and bore the cylinders to match?
    79 XS1100 f (BIGDOG)
    80 XS650 Special
    85 KAW 454 LTD
    Dirty Dan
    • teck_mountain
      • Aug 2003
      • 128
      cylinders
      You bet... one size over and bored to match
      Tim Lowe
      "Teck"
      1979 xs1100 Special
        Hey there Teck,
        Well, did you coat the cylinders and pistons/rings with straight 30 wt oil before attempting assembly? You'll probably need to put some on top of the pistons allowing it to seep around to the cylinders and rings, perhaps even some penatrating stuff, also may need to spray it in up under the pistons against the cylinder walls as well.
        Did you first check and set/file the end ring gap for your rings by putting them alone inside the cylinders? You may not have enough end gap, and so they can't compress small enough to properly fit within the cylinder??
        Next, you can try a rubber mallet and gently tap on the pistons to get them moving? Try heating up the jugs with a hot blowdryer or even a light torch?
        Good luck!? T.C.
        • teck_mountain
          • Aug 2003
          • 128
          cylinders
          great advice
          Will attempt your suggestions this evening. stay tuned
          Tim Lowe
          "Teck"
          1979 xs1100 Special
          • sixtysix
            No XS but XSive as can be!
            • 1958
            • Central New York State
            Ok where did you find first o/s pistons? Yamaha hasn't made them in a while ???
            Gary Granger
            • DEmily
              • Jun 2003
              • 220
              • Kansas City, MO.
              That's a good question. I could not fine any oversized pistons. Plenty of ring sets but no pistons. I went with standard rings and my original pistons and luckly, my cylinders will still in real good shape.
              80 XS650 Special
              85 KAW 454 LTD
              Dirty Dan
