What tubes where?
  • TexinMaine
    • 160
    • Norway, maine
    What tubes where?
    So I got my carbs cleaned and put back together but having trouble remembering what connected to the "T"'s between the 1-2 and 3-4 carbs. I know the two lower ones connect to the fuel lines from the tank but not sure what the two upper ones connect to. Also I guess my pet cocks where not hooked up correctly and they need to be connected to the manifolds?
    From here
    to here?
    I think this goes to the airbox?
    And finally what does this hook to? Its the #2 carb.
    Thanks!
    Tex
    1981 XS1100H
    Quando omni flunkus moritati
    When all else fails, play dead.
  • wjw11teen
    • Mar 2014
    • 93
    • Valleysprings.S.DAK
    the big hose in the 3rd pic goes to the air box...should be right in the center of it
    the tube on the #2 carb should get the vaccum line from the vaccum advance coming from the left side engine cover
    i think the vac tube on the rubber intake boot should go to the petcock in the first pic
    81 SH gifted to SON
    • TexinMaine
      • 160
      • Norway, maine
      Ok, that must be what the clear hose by the #1 manifold is for. Thanks!
      1981 XS1100H
