[QUOTE=Dylano*;441913]Well before I go on a real ride,
I've gotta get the brakes right,
Put on my new front tire,
Soften my suspension some,
Vacuum sync the carbs,
And adjust the valves!
Then all the cosmetic crap!
Front wire hiding shroud,
Remove, blast, paint, install about everything,
Re-route throttle and choke cables again, or shorten them,
Finish making gauge housing,
Make blinkers work,
Etc etc!!!
I find it inspirational !!!!! Give it and get it !!!!! Can't wait !!!!!
I can't get my carb's tuned properly with exhaust and pods. ):
I don't know picked up the same size jets from yamaha today ...tonight after work taking the carbs off to see what I have ind there and hopefully if I'm lucky I picked up the right ones and will be riding instead of driving tomorrow ...if not then tomorrow ill at least know what to getLeave a comment:
Well, it is an XJ instead of an XS, so the 8 airbleed holes in the pilot jets are not for everyone. If it works, it works. No one can argue with success (except for bull-headed managers when they couldn't take credit, but I digress...)Leave a comment:
Also did u ever figure out if the bleed type jets mattered at allLeave a comment:
I've checked the springs ...I can move by finger but alot easily by flat head..thanksLeave a comment:
I got these jets, from here:;Okay so I've read every single post here...have an 79 xs1100 standard...open pipes and pods...having the same issues with carbs...seems like I have to re sync my carbs every week or so ....one day runs perfect ..next day back fire with flame...or stuttering at low throttle ...will the same jetting work for me or do I have to experiment like you did ..bike is a dailey ride other than when its time to sync....luckly I'm close to home to deal withthe crappyness....and if it will work what size jets did u purchase exactly...from where...I belive wehave thesame cabs...
Mains:
http://www.ebay.com/itm/331196266192...84.m1439.l2649
Pilots:
http://www.ebay.com/itm/251519084489...84.m1439.l2649
If your carbs keep going out of sync maybe the spring keeping tension on the sync screws are weak/gone?Leave a comment:
Okay so I've read every single post here...have an 79 xs1100 standard...open pipes and pods...having the same issues with carbs...seems like I have to re sync my carbs every week or so ....one day runs perfect ..next day back fire with flame...or stuttering at low throttle ...will the same jetting work for me or do I have to experiment like you did ..bike is a dailey ride other than when its time to sync....luckly I'm close to home to deal withthe crappyness....and if it will work what size jets did u purchase exactly...from where...I belive wehave thesame cabs...Leave a comment:
Make blinkers work,
Etc etc!!!
Very happy and very excited though.
So conclusion to this thread:
If you want to run open headers and pod filters,
Follow the jet guide!
4 over mains, 1 over pilots.
I have my pilot screws at 4 turns out.
THEN MAKE SURE YOUR GAS TANK FILLER CAP VENT SYSTEM ISN'T PLUGGED!!!!!!! Hahaha
I think this novel sized thread should beer over now. Ill start new ones on my new problems!
Like, temperature gauge, should I install one? Same question with oil pressure gauge...
Uhh what else is there....
Should I get/make a fork brace?
Steering stabilizer?
What else should I do to this thing?!
Here is my 75% compete roughed up beast, now running and worthy of a pic thanks to all of you!
Leave a comment:
Job well done, that's a good ending! Always a good reminder to not overlook small easy stuff. We all are guilty of that since it took 300 posts to figure this out!
Now that bike is ready to come to the Colorado Rally in July if your brakes work...Leave a comment:
Right on! That's about the best news I've had all day except for my new clutch springs showing up! Yeah, it's been one of those days.
It's happened to me and a lot of other folks, glad you got it fixed now put it back together and go ride somewhere!
.Leave a comment:
Found/cleaned the vent holes,
Literally, runs PERFECT!!!!
I had to change plugs and put pilot screws at 4 turns, and she purrs, and HAULS ASSSSSSS!!!!!!
Now it's time for all the cosmetics, well before that, the brakes, and a steering damper, and new front rubber.
I seriously can't believe this entire time it has just been a clogged freaking vent hole!
before I uncloged It I went on one more test ride, and checked the fuel filter.
it was at the same level as the other, but I guess a vacuum was keeping it at that level and choking the carbs!!!
Seriously I can't thank you all enough.
ESPECIALLY YOU 3Phase!!!
Ockams razor right?!?! *slaps face*Leave a comment:
Vent hole?!?! That could be it! I have noticed that sometimes my right hand side filter would run dry... messing with the petckock was the only thing that fixed it.... when I've been riding... I've so far neglected to see if that is happening -_- I really hope that is it so I can feel like a happy idiot!!!!"Mmm, could be!" (munching on a carrot) but have you checked the fuel tank filler cap to see if the vent is plugged up?
If the vent's plugged the engine'll run and rev fine until you get on the road, then it'll pull a vacuum in the tank and basically run out of gas until it sits for a few minutes and the air pressure equalizes enough for the fuel to flow down to the carbs again.
That'd beat the heck out of changing jets again or messing up that pretty blue wiring.
.Leave a comment:
Leave a comment:
