Packing a MAC 4 into 1 Baffle with Fiberglass
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    Has anyone tryed to get more low to mid range from their MAC 4 into 1? I was thinking about removing the baffle and wrapping it with fiberglass mat and reinstalling it packed. Would this increase the back pressure allowing for a lower powerband? Wonder if their would be any advantage or disavantages by using a packed baffle?
    Maybe it would quiet them down a bit.
    • 4015
    It would definitely quiet them down, but back-pressure gain would be minimal.
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      If you just pack it without modifying the baffle then chances are you will restrict the system too much. The MAC baffle is not very 'open' as is.
      What I did with mine several years ago to try and give it a more mellow tone was this (sorry, I don't have any pics). First I sawed off everything in front of the rear plate leaving about 1" stub of the pipe ahead of the rear plate. Then I took a length of light-weight steel tubing, about 12" long, of the correct diameter to fit over the 1" stub. I carefully cross drilled many holes through the 12" long tube on a drill press and then brazed it onto the 1" stub. No front plate is needed because the packing centers the tube. Place a few wraps of muffler packing around the drilled tube and insert using the same screw that holds the baffle in.
      Doing this gave the little extra flow I needed with the carb, head and cam mods I have and rendered a very nice mellow tone, not unlike the old 'Cherry bomb' mufflers.
      The usual caveat...it worked for me...might not be right for you.
      Oh, and if you want to go back, just saw 1" off of the old baffle and the tube you installed and braze the baffle back in using the piece of tube as a ferrule.
      Mike Giroir
      79 XS-1100 Special
        I had a Mac 4 into 1 on my SF, they have a strange sound to them with that baffle. I took some exhaust wrap and wrapped it around the exit pipe inside, up against the back plate. The exhaust coming into the baffle blew up against the wrap and mellowed the sound a little and I'm sure it increased the BP some also.
        I tried some SS wool in there but it just kept blowing out the tailpipe.
        My SF was crazy fast through all ranges.
