Fuel Line Question
  • Graman
    • Oct 2012
    • 43
    • Surrey, BC, Canada
    Fuel Line Question
    I have a beautiful 79 XS1100 Special that I have been slowly restoring over the last couple of years. I have rebuilt the carbs but I noticed when putting it all back together that the fuel lines are getting a little rotten. I went out and got some new fuel line but I couldn't get the smaller o.d. like the original. All I could get was pretty much standard automotive line. I have replaced all the lines but things are getting a little crowded in there. It's hard not to get pinched lines when I lower the tank back down.
    My question is. Is there anything wrong with running just a single line from the prime side of each petcock directly to the each carb? I can cap off the unused petcock connection and the vacuum line to the diaphragm valve from the carb boot and eliminate all the unused plumbing. This would give me way more room under the tank. I usually shut the fuel off when the bike is parked anyway.
    Graham in Surrey, B.C., Canada
    1979 XS1100 Special.
    Mac 4 into 2 chrome exhaust.
    Dyna high performance coils.
    Drilled air box.
    K&N air filter.
    Pics https://www.dropbox.com/sh/4tpyuurw3...XjCLWeTVa?dl=0
    ........or your best bet is to not use automotive fuel line as some have had issues with tiny pieces getting places where they should'nt from pushing on and off barb fittings. Don't know your exact location, but surely there's a small engine, mowers, etc. business that WILL have the tygon fuel line you need. Comes in milimeter sizing, so correct fit is painless.
      • 7949
      Motion Pro Premium fuel line is a joy to work with. I love the stuff. It doesn't like tight bends, so I plumbed mine from the right petcock to the left carburetors and the left petcock to the right carburetors. I have retained the vacuum shut-off. This fuel line is still very pliable after a couple of years.
      • graybird78
        • Apr 2003
        • 360
        • council bluffs iowa
        +1 on martys suggestion.just redid my fuel lines on my 80sg.motionpro was the way to go. tried to use the tygon but was to flimsy for my liking. motion pro is twice the wall thickness of the tygon. much better fit in my opinion.
        when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
        graybird78
        80 sg (old faithfull)
        • Winterhawk
          • Jun 2004
          • 684
          • Missouri
          2nd the Motion Pro. The only way to go I think. All Motion Pro stuff is good.
          • Graman
            • Oct 2012
            • 43
            Thanks guys. I am going to look into these products. Most of the parts dealers up here don't have access to the variety of stuff you have down in the States. They just shake their heads and say they've never heard of it. If not I think I am going to run lines from the main line of the petcocks straight down to the carb. Using that side should still allow my reserve setting to work. I plan to install some inline filters for extra safety. Then cap off and remove the rest of the plumbing.
            Drilled air box.
            K&N air filter.
            • tweeleft
              • May 2009
              • 110
              • Bend Oregon
              I capped the prime so I still have the reserve feature, also use clear small engine tubing from O'Rielly's, including the vents to the airbox. That way I can see if my floats are stuck. No more octy. Good Luck
              Keep the shiny side up
              1979 XS1100SF
              Mac 4-1
              Drilled airbox Uni filter
              Vmax bars
              Virago 1" shorter shocks
              30K miles
              http://i1228.photobucket.com/albums/...429_135845.jpg
              1981XS1100SH
              '80 G Forks and Triple Tree
              '80 G tank
              Mac Turnouts
              Virago 1" shorter rear shocks
              SH Headlight
              http://i1228.photobucket.com/albums/...psd6adaae1.jpg
              61 Wife
              83 Son
              86 Son
              89 Daughter
              • Graman
                • Oct 2012
                • 43
                I went ahead and completed the mod yesterday as previously described. Works great. Lots of room under there now. I was even able to leave a few inches of slack so I can lift the tank high enough to get at the carb adjustments without disconnecting the fuel lines. Thanks for the feedback.
                Drilled air box.
                K&N air filter.
                  so what size of metric tube do we need?
                  Time I replaced the fuel lines on mine.
                    1/4" ID fuel line
                    • Prisoner6
                      • Aug 2013
                      • 1184
                      • Phoenix, AZ
                      Originally posted by natemoen
                      1/4" ID fuel line
                      ... which corresponds to 6mm ... actually, 6mm is ever-so-slightly smaller than 1/4" ... lots of places list them (1/4" and 6mm) as one-in-the-same size/product.
                      Marco
                      1979 Honda CBX
                      2002 Kawasaki ZRX1200R
                      WE MISS YOU, DON
                      • Graman
                        • Oct 2012
                        • 43
                        I just used standard 1/4 i.d. auto fuel line from the local Napa shop. You will need some hose clamps too. The old stock ring clamps won't open up enough to fit the fatter o.d. fuel line. I didn't install the inline filters that I had planned to add. I pulled the petcocks out a while back when I painted the tank. The built in filters were in brand new condition so I decided against additional filters.
                        Drilled air box.
                        K&N air filter.
                        • James England
                          • 3039
                          • North of England
                          No it's not.... their valve shim tool is rubbish. I just bought one and got rid of it....
                          • rdmcguy
                            • Jul 2013
                            • 515
                            • Denver, Colo.
                            motion pro
                            +1 James
                            bought some fuel line and it swelled up and leaked.
                            Also bought a sync pro carb stick,leaked like a sieve,
                            called them left a message,never heard back, called again and they wanted me to pay return postage on a brand new tool .
                            I told them I thought that was b.s. and they sent me a new one
                            they didn't want the old one back.
                            • TexinMaine
                              • 160
                              • Norway, maine
                              I just bought some fuel line today from a Motorcycle shop. It is a 1/4" and clear yellow. The guy says it is not degraded by the gas. Seems pretty flexible and easy to work with.
                              1981 XS1100H
                              Quando omni flunkus moritati
                              When all else fails, play dead.
