setting/tuning air mixture screw
  • unicorncomputer
    • Jun 2012
    • 140
    • Southern Vermont
    I have a 79 XS1100 Special.
    I have cleaned the carbs and put the mixture screws back the way they were.
    all were 1 1/8 out.
    the bike is running really rough though, to the point I don't think I can ride it.
    I understand the normal starting point is 1.5-2.0 turns out so I am going to change it to there.
    how do I tune or dial in the mixture screw? I have vacuum gauges, but do not have colortune or any other devices.
    Thank you,
    Steve
    79 XS1100 SF
    • 4013
    Mixture will be best determined by a plug chop @ idle with a fan blowing on the engine. Clean the plugs, etc. Carbs will then have to be vacuum-synced post-mixture adjustment.
    • unicorncomputer
      • Jun 2012
      • 140
      • Southern Vermont
      Sorry, but I don't know what you mean by a plug chop at idle.
      Can you explain more.
      The plugs are new this season and gapped at .30
      79 XS1100 SF
        • 9981
        The idle mixture can be set with the sync gauges but it's very difficult to explain.
        It requires patience and the carbs need to be resynced repeatedly.
        Set all cylinders to the highest vacuum with the mixture screws, resync and repeat that procedure until the carbs are synced and you can no longer increase vacuum on any cylinder with the mixture screws.
        This method will generally leave you a little lean so if you experience popping from the exhaust open each screw 1/4 turn one at a time until the popping stops or changes. If you open one as I said and it doesn't change the popping turn it back where it was and go to the next carb.
        Like I said, hard to explain but it's easy to show someone how to do it.
          • 8930
          See if it is firing on all 4 at idle, spritz the headers with water.
          • SFerinTEXAS
            • Jun 2006
            • 877
            Have you confirmed no mixture screw tips broken off? Early carbs are known for this. My 78 had all 4 broken off when I got it.
            79SF
            XJ11
            78E
            • unicorncomputer
              • Jun 2012
              • 140
              • Southern Vermont
              Yes, when I got the bike in 2012 and had to do a rebuild of the carbs, we found 2 broke off, what a pain that was for my Brother-in-law to get out.
              I have gotten everything set, just before the rain started tonight.
              Hopefully tomorrow will be nice so I can get on the road with it.
              Steve
              79 XS1100 SF
              • alaskey2
                • Apr 2014
                • 271
                • 60940
                Can I check if my mixture screws are broken without pulling the carbs?
                78 E
                • mack
                  • 2411
                  • Ontario, Canada
                  Yes
                  Yes, back them out all the way. Once removed look at the tip's. If they aren't needle sharp with a long point and the same length, then the short ones are missing tips. Now whether the tips are still in the carbs is another story. Try inserting a long one in the suspect holes and see how far they will screw in. Be gentle. if they don't go all the way down, you still have the tips in there. Once you've removed the carbs(if that is in fact the case) you will feel and see the tip sticking through the hole in the carb throats.
                  mack
                  79 XS 1100 SF Special
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  https://youtu.be/wB5Jfbp6SUc
                  https://youtu.be/RaI3WYHSuWA
                  Frankford, Ont, Canada
                  613-398-6186
                  • alaskey2
                    • Apr 2014
                    • 271
                    • 60940
                    Awesome, Thanks!!!
                    78 E
                    • mack
                      • 2411
                      • Ontario, Canada
                      gently
                      Remember I said gently. If your too aggressive you will have two broken tips in there.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        It might be advisable to take the spring off before you screw it in, it is easier to feel it hit something that way.
                        CZ
                        • alaskey2
                          • Apr 2014
                          • 271
                          • 60940
                          Ok, now I'm really confused. They dont't seem to go in the same amount. The inner carbs are shorter. Also, my carb3 drain bolt has old gas on it and i pulled the air filter and it smelled lime gas too. Guess that is why my MPG sucks
                          78 E
                          • mack
                            • 2411
                            • Ontario, Canada
                            Ok
                            so did you manage to get the #2 & #3 screws out and look at the tips ? I know they are hard to get to while the set is on the bike. Do they still have sharp points or are they blunt ends.
                            mack
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            613-398-6186
                              Hey Alaskey,
                              First of all, as was stated, IF the tips are broken off in the carbs, then the pilot screws will NOT screw down the same distance, because it will/may be hitting the end of the broken piece from the other screw? OR...they had gotten broken off by the PO, he/she removed the broken pieces, fixed/filed down the broken screws back to a point, but they are now shorter and so will screw in farther before seating!?
                              Secondly, the fuel ON the drain screw isn't necessarily indicative of a leaking drain screw. You found fuel IN the airbox/airfilter. That's an indication of a leaking carb due to a float needle valve/seat combo not sealing properly and likely flooding while riding, or worse....leaking while parked...which can be bad because the fuel can then leak forward thru the carb throat and intake manifold and into a cylinder....and if that cylinder's intake valve is even just partially open, will allow fuel to get into the cylinder where it can then easily leak down past the piston rings and into the crankcase where it then contaminates the oil, thins it out too much and can cause engine destroying bearing damage to the mains and con bearings, as well as cams!
                              SO...you will want to check your oil to see IF you can smell/detect fuel in it, but it's difficult when it's not much, but it only takes a little bit of fuel to contaminate the oil to the damaging level/viscosity. We used to recommend putting stick in the oil and then try to light it...but learned that it wasn't a valid test....that one could still have a damaging level of fuel contamination but would not be enough to allow it to light on the stick! SO....if fuel in the airfilter, it's best to just bite the bullet and change the oil/filter, but check and fix the leaking carb problem FIRST or you'll end up having contaminated oil again!
