Thanks Randy
Swampthing sprung a leak...
Ben, I know you said no valve cover leak, but that's where most of them will show up if it's leaking on the left side. Especially in that U-shaped area around plug #2. Get a flashlight and look in where the #2 spark plug is and see if it's getting wet in there. It likes to blow through the head, hit the #1 or #2 carb holder, and drip down right onto that top fin of the cylinders where the head meets the cylinders. The way the motor sits, and most lean on sidestand, it'll run down around and drip at the front there looking like a head gasket. BUT... a leaky cam chain tensioner can make it up and through there the same way.
Poor Randy is shaking his head at what's become of his beauty..Try your hardest to be the kind of person your dog thinks you are.
Originally posted by trbig View PostBen, I know you said no valve cover leak, but that's where most of them will show up if it's leaking on the left side. Especially in that U-shaped area around plug #2. Get a flashlight and look in where the #2 spark plug is and see if it's getting wet in there. It likes to blow through the head, hit the #1 or #2 carb holder, and drip down right onto that top fin of the cylinders where the head meets the cylinders. The way the motor sits, and most lean on sidestand, it'll run down around and drip at the front there looking like a head gasket. BUT... a leaky cam chain tensioner can make it up and through there the same way.
I'll look where you said in the a.m. right now I'm dealing with a sick pet...so that takes precedence...1980 XS650G Special-Two
1993 Honda ST1100
1993 Honda ST1100
OK, where is the oil coming from? The only place there is oil that is sealed by the head gasket is in the cam chain tunnel and that isn't under pressure.
Where from the head gasket is it coming from?Greg
Originally posted by BA80 View PostOK, where is the oil coming from? The only place there is oil that is sealed by the head gasket is in the cam chain tunnel and that isn't under pressure.
Randy had this motor apart in a rebuild about 3 yrs ago...Last edited by madmax-im; 04-27-2014, 04:06 PM.1980 XS650G Special-Two
1993 Honda ST1100
The cam chain tunnel is in the center, front and rear. Be sure it isn't just the oil transfer tube copper gasket on the banjo bolt that connects it to the head. That's just above where the head gasket seals the cam chain tunnel. In between #2 and #3 carbs right by where the throttle cable sheath mounts.
It's hard to get to and hard to see but try and get in there with a wrench and tighten it. The tube runs up between #3 and #4 carbs and bends over to the center.Greg
Originally posted by BA80 View PostThe cam chain tunnel is in the center, front and rear. Be sure it isn't just the oil transfer tube copper gasket on the banjo bolt that connects it to the head. That's just above where the head gasket seals the cam chain tunnel. In between #2 and #3 carbs right by where the throttle cable sheath mounts.
It's hard to get to and hard to see but try and get in there with a wrench and tighten it. The tube runs up between #3 and #4 carbs and bends over to the center.1980 XS650G Special-Two
1993 Honda ST1100
Just trying to save you some time and money. It's free to tighten a bolt.Greg
Originally posted by BA80 View PostJust trying to save you some time and money. It's free to tighten a bolt.1980 XS650G Special-Two
1993 Honda ST1100
I'm sure I've said this before but that's what it was on Doc's bike when we were sure it was a head gasket leak.Greg
Doesn't add up. For oil to seep from the center tunnel to outboard of cyl #1 it would have to get by cyl #2 AND that head would have to be really loose, which would mean lots of blow-by across cylinders and rough running.
From 1000 miles away. I'm going with oil pipe. Even though those crush washers were renewed 3 yrs ago. I HAVE seen ruptured / cracked oil pipes do that.
There is also the oil pressure gauge connection to the sender there between the carbs and the head. I put braided Teflon line in there but one of the banjo's could be weeping?
It's going to take more than a mirror to figure this out, but there are some ideas from the guy who built this.Former owner, but I have NO PARTS LEFT!
well I just tried to look in depth and i still cannot see where any oil has traveled to where i see it leaking...since i dont really know squat about the oil lines and such...theres a 99.9% chance that you get to see it in person in the next 19 days or so...1980 XS650G Special-Two
1993 Honda ST1100
