Swampthing sprung a leak...
    • 6762
    Ok I noticed some oil splatter on the left side of the engine...
    So upon closer inspection i find the source...
    Minor for sure but what to tighten?
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Ben, It looks like the head gasket. You might want to check the compression on #1 there and see if it's dropped any. (or at least see if it's lower than the other 3)
    That might show if the gasket has failed at the piston area and not just the oil area.
    When my head gasket blew, it was blowing out exhuast gasses out between the head and cylinders. It was quite noticeable.
    As you can see the gasket failed between #1 & #2
    Though, I don't remember there being any oil passages on the outer sides of the cylinders, so maybe your leak is from the front and it's getting blown around the left side.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
      • 9980
      More than likely the valve cover gasket or the oil transfer tube is leaking an blowing around the engine on the finns. A head gasket wouldn't blow oil.
      When the oil transfer tube gasket was leaking at the back of the head on RockinD's bike the oil ran around the head and looked almost like it was coming out of the #1 exhaust port. A valve cover gasket will do the same thing if it's leaking in around the spark plug wells. It'll leak out the water drain holes and look like it's coming out the head gasket or exhaust.
      • DAVINCI
        • Jan 2011
        • 1048
        • Cedar Mountain, NC
        Yeah, I would go around and make sure nothing loosened, check the torque on the valve cover, head nuts and chain tensioner. BTW, it has the auto chain tensioner.
        You sure its from you? Could have run into something? Does it taste like maple syrup?
        Wash and ride see what happens?
          • 6762
          gonna take the bike out of the shed and take a very close look...
            • 6762
            looks like head gasket leak
            ACCT area is greasy but its dry compared to the gasket area
            no tubes or hoses off or leaking
              • 8863
              That leak is probably coming from the valve cover and just blowing around and collecting down there. I'd clean it off with some brake cleaner and a rag and check around the valve cover for leaks. It also might be leaking from the metal oil tube that feeds oil to the head.
                • 6762
                ok I'm fairly certain the valve cover gaskets are clean and dry...nothing from that area...just went to double check...
                • Truefreak104
                  • Nov 2013
                  • 38
                  • Florence, Or
                  I'm having the same issue ...but it looks like the oil is coming off myfloat bowls....head and all fins r dryno oil anywhere but the carb rail
                  79 xs1100 standard ....Bobber project
                    • 3932
                    Lol, obviously your carbs are not leaking oil. My leak is directly below your's.
                    • Truefreak104
                      • Nov 2013
                      • 38
                      • Florence, Or
                      Yea I thought it was fuel at first bit nope golden oil....pulled the carbs and everything is dry ....
                        • 9980
                        Dang Ben, Wash that thing!
                        The nastiest mess is right there around the tensioner, clean that up and keep an eye on that.
                        And change those old rusty plugs! I wonder how long those have been in there.
                          • 6762
                          Springtime tuneup will ensue next week after paycheck arrives...will check and torque the head bolts and will change oil and filter...and clean up engine grime... replace those rusty plugs or clean them up too... I'm not much on cleaning things...i ride it as long as all the fluids stay where they're supposed to...this bike is not a museum piece its gets ridden daily
                          BTW whats the best way to clean that grime out of the ACCT area? would a can of brake cleaner be ok? I have checked carefully and no oil is running from the ACCT to the area where i see the gasket leak
                            • 3932
                            Yeah, brake cleaner and a tooth brush. Although, I can't take my own advice, as I think it'll peel the paint off my engine. Maybe degreaser for me.
                            • DAVINCI
                              • Jan 2011
                              • 1048
                              You know, ben, that greasy stuff on the front may be residual. I couldn't get all of it out, didn't have the facilities in my little apartment. Why don't you simple green / engine degreaser / power wash it.
                              Don't use brake cleaner, it will dissolve the paint. The engine has a coat of high-heat aluminum on it.
