refreshing the bike
  • thebottle
    • 158
    • Wisconsin
    refreshing the bike
    So in a few weeks I'm going to be putting in new rings, cam chain, fixing the transmission dogs, checking clutch plates. With the engine this far apart is there anything else that I should be updating? I don't want to pull it apart again for awhile!
    1980 XS1100SG
    1998 KLR 650
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Might think about a set of heavy duty clutch springs while you have the side cover off. they are relatively cheap and will cure that nagging clutch slip we sometimes get.
    Mike Giroir
    79 XS-1100 Special
      • 4015
      Clean-up the head, maybe a quick clean of the valves, valve oil stem seal replacement, obvious valve lash check, new gaskets for your intake boots?
        Take a look at the starter clutch if you feel ambitious...
        • thebottle
          • 158
          • Wisconsin
          Yeah, that is something I probably should because it seems to slip quit a bit, but it's colder here so that may be the problem. I don't want to split the case though... .
          1980 XS1100SG
          1998 KLR 650
            • 4015
            I was gonna say "that requires splitting the case though . . ."
              Yeah, splitting the cases is scary, but Tod/Trbig will tell you it's no big deal, and has posted a HOW TO on it. However, like you said, the cold weather/temps can cause starter clutch slippage. Where you live, you might want to 10-40 for winter, and have a strong battery...that's what also contributes to starter clutch slippage...weak rotation causes weak grip=slip!
              I would definitely freshen up the valves....a good lapping along with as already stated, the oil seals. Checking the clutch plates.....also clean/deglaze the steels.
              Okay, new cam chain, then either put on an ACCT or make the carriage bolt MCCT mod, but whichever, just get rid of the OEM CCT.
