my 79 standard is having issues. the jerky feel at low speeds and the growl and vibration at higher speeds have me thinking I have a bad u-joint. but other things come into play previous owner rode this bike HARD.I have thought for some tie that I had way too much clunking going on in the middle drive when dropping into gear from neutral for one. that and the fact there was almost no oil in it.
...anyhow, last year while attempting to get rid of vibration, I switched from my 79 tube rims to- new tires on my 80 tubeless rims. balanced them.NICE but did not get rid of the high speed vibration. I don't believe that my 80 rear wheel mounting to my 79 final drive is going to amount to any vibration
....anyhow, my clutch has also started slipping quite a bit ( hoping to swap parts again with the 80 ? ) swingarm bearings could probably use grease or adjusting...last year I changed the steering stem bearings...they were almost non existent.
SO. any advice,tips , suggestions , heads ups.would be greatly appreciated!
I am hoping to take the '80 parts with lower miles (12k) and replace the '79 parts (that have about 55k )
clutch-middle drive-u joint,drive shaft,and final drive.
last spring it was steering stem bearings,wheels/tires,rebuild the carbs,reshim the valve clearance,and rebuild the brake calipers.
I hope to keep the down time to a minimum.with your help I should be good. I did print off the Drive Shaft service manual and the pages of the OEM book on middle drive removal from Steve's page. Thank you. and thanks again for any advice you XS'ers have to offer.
His advice of looking for metal fillings in it would also apply to the Final Drive as well, but they are much more durable than the middle drive.
