Yamaha XS 1100 Eleven Special Main Stand
  • Ben Geutskens
    • Jan 2014
    • 35
    • Norg, Netherlands
    Can anyone send me a phoptograph of the main stand (centre stand) in folded up position in relation to the mufflers? On my bike the upward movement of the main stand is limited by the mufflers and not by a stop plate as I expect. The stand cannnot be totally folded up, resulting in the stand hitting the road when going through a curve. I can hardly put the mufflers higher up without too much force.
    79 SF Canadian
    • 3957
    I guess my first thought is if you have OEM exhaust? Spring still there? Cross-over pipe in the way? Mufflers mounted properly in the rear?
      OEM or aftermarket exhaust? It sound like you have a 'standard' centerstand installed with 'Special' exhaust; look here:
        • 3957
        Hey Steve- Where is the brackets on the Standard, for holding the kickstart lever?
          Under the battery. There should be a screwed-on spring clip to hold the 'kick' end in place.
