running really rough and stalling
  • unicorncomputer
    • Jun 2012
    • 140
    • Southern Vermont
    Just got the bike running for the season, took it out for the first ride. It was running a little rough in low rpms, but I figured it was just gettting cleaned out. I put some seafoam in, changed plugs and battery. It is getting worse. it is running rough even up around the 3-5k rpm now and will stall if I let it come to an idle. Do I need to pull the carbs and clean them?
    I pulled the air filter, it looks fine.
    not sure what to try next.
    Thank you,
    Steve
    79 XS1100 SF
    That would be the place to start if it was running good when you parked it last fall.
      • 9980
      Pay most particular attention to cleaning the pilot jets, pilot circuit and idle circuit.
      • unicorncomputer
        • Jun 2012
        • 140
        • Southern Vermont
        I know what the pilot jet is, but what is the pilot circuit and idle circuit?
        Thank you,
        Steve
        79 XS1100 SF
          • 9980
          Those are the passages. Those 2 circuits are actually part of the same circuit if that makes any sense. They control fuel and airflow from idle on up to about 1/2 throttle.
          Here's a kind of a crash course on the operation of these carbs. Read the text don't just look at the pictures.
            Parked for some time, liklihood of a mini science project inside carbs is pretty good. When U remove pilot jets and emulsion tubes, use a magnifying glass under good light to look down inside/thru pilot jets and emulsion tubes. Be surprised, magnified, what you'll see. Clean all air-bleed side holes on both these components with a toothpic......no metal. Make sure teeny hole in bottom of pilot jet is cleared. Just went thru all this on my Venturer leaving it set in corner of man-cave with bike cover on it for a year since I was riding my other STeed......lesson learned, and not sure if Star-Tron or any other stabilizer would of helped retard that from happening.
            • unicorncomputer
              • Jun 2012
              • 140
              • Southern Vermont
              Just pulled them off, haven't torn them down yet. Headed out to get some cleaner.
              Really surprised, put in seafoam and ran for 10 minutes, put carb stabil before storing and empting carbs.
              will see what happens.
              79 XS1100 SF
              • MPittma100
                • Aug 2011
                • 2359
                Ethanol
                You can thank the ethanol that is in our gas for your current problem. Next time it is going to be stored, you should leave non-ethanol gas in the fuel system. If it is not available to you, you are better off draining the entire fuel system - tank, carbs, and lines. Seafoam nor Stabil are effective (enough) to combat the ill effects of ethanol.
                mike
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                  • 9980
                  I will go out and start my bike every week or 2 when it's to cold to ride and let it run for 15 or 20 minutes just to avoid this problem. I haven't had to take the carbs off of mine in 3 years.
                  • unicorncomputer
                    • Jun 2012
                    • 140
                    • Southern Vermont
                    Gets too cold here even to get it to start it in Vermont.
                    Sure enough, there was crap in the bowls.
                    Something I noticed, the tube that the main jet screws into on carb 1 and 4 has 4 sets of holes cross drilled while carbs 2 and 3 have 2 and 3 sets cross drilled.
                    Is this correct? Supposed to be this way?
                    As always thank you all for you assistance.
                    I will try and find somewhere that has ethonal free gas.
                    79 XS1100 SF
                      • 9980
                      Yes, the emulsion tubes with fewer air bleed holes go in carbs 3 & 4. The 2 center cylinders need more fuel to help cool them because they get less airflow.
                      • unicorncomputer
                        • Jun 2012
                        • 140
                        • Southern Vermont
                        Do you mean the emulsion tubes with fewer holes do go to 2 and 3(inner cylinders)?
                        79 XS1100 SF
                          • 9980
                          YES! That's what I meant.
