Are these right?
  • Eastcoaster
    • Jan 2012
    • 513
    • oceancity NJ
    Are these right?
    Cleaning a set of carbs off 1979SF Here is what I found
    Could this be correct?
    Bike has a 4 to 1 exhaust that's the only mod
    82 XJ1100J
    81 Venturer
  • TomB
    • 967
    • Cumbria, UK
    I don't know sorry, but have just assembled my carbs and never noticed, got me wondering now. They all looked the same in my carbs but could be model specific? mine are 2H9 Standard
    Tom
    • mack
      • 2411
      • Ontario, Canada
      needle jets
      Yes there was two different tubes used. The principal was that the inner two cylinders don't get the same air flow as the outers so will run hotter. To compensate more gas is pushed to 2&3 so they can run a bit richer. If I'm not mistaken, the more holes the more gas so you will want to change yours around. The jetting sounds correct for your exhaust if your not running pods on it.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
        The holes are air bleed holes. The more holes the more air is introduced to the mix. Fewer holes go in the middle, more holes go on the outside.
          This is correct.
          • mack
            • 2411
            • Ontario, Canada
            Sorry
            Good god, the only thing worse than not knowing, is getting bad advice.
            Been a while since I've worked on the 78/79 carbs. Nice catch Nate. Seems this was a discussed at length a few years ago when someone produced a chart that was in error as well.
            Eastcoaster listen to the pro's not me! Their right all the time. As for me, I will make sure I have finished my morning coffee and am thinking straight before I open my mouth.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              More bad advice
              I am wrong very often!
                'Bad' advice is rare here.... Now, 'incorrect' advice can be a bit more common...
                • Winterhawk
                  • Jun 2004
                  • 684
                  • Missouri
                  That is excellent info on the Needle Jets. I had no idea. This site with the members input is a God Send. I've used advice from here many times over the years even with Bob Jones.
                  Thanks
                  • TomB
                    • 967
                    • Cumbria, UK
                    Eastcoaster, could you tell me what numbers/letters they have stamped on them?
                    Tom
                    • mack
                      • 2411
                      • Ontario, Canada
                      Numbers
                      Had two coffees so I'm ok now. Tom the numbers stamped are: X2 for size on both and 1 + 4 should have the four holes all around are series 266, The ones for 2 & 3 have the 2 and 4 hole combination and are series 301.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                      • Eastcoaster
                        • Jan 2012
                        • 513
                        • oceancity NJ
                        numbers
                        Here is the best I can tell
                        1 and 4 x-2 266
                        2 and 3 X-2 301
                        All cleaned up Do you think I am good to go with these?
                        82 XJ1100J
                        81 Venturer
                        • Eastcoaster
                          • Jan 2012
                          • 513
                          • oceancity NJ
                          YUP Talk about bad info
                          Mack you have them right!!!
                          Do I dare tell you how many times I read them upside down and was ready to post!
                          Thanks everyone
                          Coaster
                          82 XJ1100J
                          81 Venturer
                          • TomB
                            • 967
                            • Cumbria, UK
                            Thanks fella's
                            I have a set of Special carbs to do next, so handy to know, I've never done Special carbs before.
                            I've checked my 2H9 carbs have all X-2 266.
                            Tom
                            • TomB
                              • 967
                              • Cumbria, UK
                              I've been using this site for some good info.....
                              Jetsrus.com
                              Tom
