Hey TC - Yes I did remove the emulsion tubes and pilot screws before soaking the carbs, replaced the little o-rings, too. Bike has fresh oil and filter.
Brent - thanks, I'll check the connections you mentioned...special tool required for the cable or just squash the crimp tighter with big pliers?
Sounds like I did the float height measurement correctly, thanks to those who verified. I will check the fuel level with some clear tubing (have already shimmed front tire and center stand to insure carb bank is level), no sense yanking the carbs if they are right
Then new plugs and put some miles on it to check coloring, temps in the 60's later this week...finally!
