Went to adjust my rear brake lever...need rebuild for master
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    Any kit ya'll recommend?
    My master is leaking
    unless there happens to be a modern replacement for it?
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • 1966
    Sparky
    you could look for Georgefix on Ebay and PM him. He can tell you what kit you need for the rebuild and actually sell you one. Have you figured out where it is leaking. If from the shaft area where the rod actuates the pump then the kit will help you. If you need the rubber diaphragm under the cap, they are no longer sold by Yamaha and will be harder to attain. Can still be had just a little more costly.
    • Tat2demon
      • Jun 2012
      • 718
      • Sioux Falls, South Dakota
      +1 On Georgefix.
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        • 8050
        George Fix has a website if you care to skip eBay.
        That's how I do it.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          yes, its leaking from the shaft/piston area
          I'm guessing this'll do the trick
          Thanks guys, I ordered from him on ebay once, didnt know he had a website
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            • 8050
            The George Fix kit will do the trick.
            matches 2h7-w0042-00-00
            If you prefer OEM, Partzilla has the kit discounted to under $50.
            2H7-W0042-00-00 CYL KIT,MASTER
              • 1966
              just rebuilt both my mc
              both came from georgefix and they are both working fine. No need to spend the extra money on OEM. Might want to pick up some red rubber grease from my earlier post and go ahead and check the calipers and front master while you are at it. If the rear is giving you problems then for safety's sake I would spend the time to look at the entire braking system. Time well spent IMHO.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                I'll look for this grease you speak of...I've never heard of grease for rebuilding masters..
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  • 1966
                  Makes it easier to assemble
                  And the RRG just melts away when you start pumping the brake fluid when you bleed your calipers. The RRG is good in the calipers when you put the caliper seal in. I also coated the caliper pistons with the stuff which made them a snap to slide back into the caliper. I was also able to bleed my calipers much quicker then when I did not use the stuff. As I stated in another thread I have also replace my brake lines with SS and that may have also contributed to the easier bleeding. Hopefully you can find some of the stuff. Check out my other post on the subject... I provided a link to pick up 500g for as cheap as I have found it.
