Where to measure float xs1100 sg
  • vedgar
    • 310
    • Clarkston, Michigan
    The carb body has a rib running the perimeter of the body base or you can call it where the the gasket seats. Should the float height measurement be from the top of the rib or the base of it ( flat surface) . I may be splitting hairs, but the difference is about .35 mm.
    Vance
    79 1100 SF Carmine Red stock
    85 Honda v65 Magna
    • 8672
    It shouldn't really matter, as long as you do them all the same way. I myself measure from the base.
      • 7783
      It's the flat surface..
      • MPittma100
        • Aug 2011
        • 2359
        Float eight
        If you use a dial caliper, the depth "foot" will sit right on the flat part of the carburetor body. I also measure from here.
        The Yamaha manual gives you a variance to set the height. You have a minimum and a maximum rather than an exact number - i.e. 25.7 + or - 1mm.
        The raised line on the body is designed to keep the gasket from moving when the bowl screws are tightened. Measuring from the line or the flat does not matter. All floats do need to be set the same from either position.
        MP
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          • 8672
          Plastic float setting (80-81) is 23mm.
            • 2072
            Hi vedgar, here's a thread that may be of interest to you:
              That +/-1mm causes a big change in carb operation though!
              • MPittma100
                • Aug 2011
                • 2359
                Float Height
                Interestingly, the spec for the newer floats is 23 + or - 0.5mm instead of + or - 1mm for the older floats?
                Nathan, what performance change have you seen in the 1mm height difference? Which height performs best - higher or lower?
                Mike
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
                  Significantly richer to significantly leaner.
                  • mack
                    • 2411
                    • Ontario, Canada
                    Best way
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
                    • vedgar
                      • 310
                      Thanks to all
                      Running great at idle and 1/4 throtttle up. Gotta figure the low end bog. May be a little lean , cause it is slow to warm up and gets better as it warms up.
                      Vance
                      85 Honda v65 Magna
                      • mikubuilder
                        • Jul 2011
                        • 548
                        • Westland, Mich.
                        Just a suggestion, you wanna mess with carbs on a warm engine. ..hence the "fan at front of it" suggestions
                        Nick
                        1982 Virago 750 (it's alive!)
                        • MPittma100
                          • Aug 2011
                          • 2359
                          ALL Four
                          Vance
                          Make sure all 4 pipes are hot during warm up. Check with heat gun, spray water bottle. If real brave, use the hot finger test. Some of these bikes are just that way. I have a 1980G that is stubborn when cold and a 1981H (with same jets) that warms up quickly and is ready to go?
                          MP
                          K&N Air Filter
                          ACCT
                          EBC Front Rotors
                          Mike
                          • vedgar
                            • 310
                            better than box fan
                            Have a carpet cleaners (air mover) for tuning and keeping bike and me cool. It really puts out a good column of air. It is better than a box fan.
                            85 Honda v65 Magna
                              • 2072
                              Originally posted by mack
                              X2 I agree, but the level shown looks low, should be up to the body side of the gasket surface, might be just the pic.
                              I have found the rulers, digital calipers, etc. too cumbersome for accuracy so I made a gauge from an old gasket:
                              Just leave a BCH loose to account for the embossed bead on the gasket surface:
