Potential new project
  • James England
    • 3039
    • North of England
    #106
    Another little update
    Well, folks, I've made some more progress on the current project and thought I'd post a few pix.
    I got the engine blasted and repainted using VHT engine enamel. It needs heat to cure so I was able to bake the smaller, removable components in the oven. For the crankcases, barrels and head, I placed two electric fan heaters next to the engine and heated it up for approx 24 hours (I'm not looking forward to my next electricity bill).
    I had some reservations about getting the engine back into the frame but it was dead easy because I'd removed loads of components. No middle gearbox, sump, oil filter housing and cam cover made life easy and I just lowered the frame onto the engine which I'd placed on its side. I've often wondered how Yamaha got the engines into the frames in the factory and made what I think is the mistaken assumption that they built a whole engine and somehow plonked it in there. Now, I reckon they put partial engines in and then added all the other bits afterwards.
    I then got the forks, swing arm and wheels on so that I can trundle the bike about whilst continuing with the project.
    So here's a few pix of the progress....
      • 3192
      #107
      Looking Good James!
      I highly doubt that they put them in without most of it assembled already. If I can spend about 200 bucks and make a machine that will lift the engine out and reinstall it complete (although I usually take the oil filter cover off for a wee bit more wiggle room), then I am sure those Japanese fellows have a really good one.
      On a full dresser I just have to remove tank, carbs and airbox, exhaust and anything that is attached to the engine mount bolts. Any wiring is disconnected and drive shaft bolts are out. The Fairing must at least be tipped forward but removed is preferred.
      Once everything is out of the way except for the actual mount bolts, I can slide in, hook up and remove an engine in 2 1/2 minutes by myself, as long as the mount bolts are free enough to come out easily. Engine paint on install is not a problem due to the way it gets hooked up.
      I am actually Patent Pending on this idea and it works ever so smooth.
      So if I can make one work after a few beers worth of thinking, I am sure those big budget factories have it all in hand. [/QUOTE]
      • James England
        • 3039
        • North of England
        #108
        Do you have pix of your engine removal system then? Or do you have to keep it under wraps whilst it's patent pending?? I'd be curious to see it!
        • jwhughes3
          • 2798
          • Home of the Alamo
          #109
          Tod is a machine!
          This engine removing machine picked up that engine we had just removed from Enterprise and lifted it onto the workbench. Runs on beer.
          John
          '81 XS1100H - "Enterprise"
          • James England
            • 3039
            • North of England
            #110
            John
            Impressive, but it's an engine replacement without bashing the frame machine that's really needed. Would an increase in beer intake facilitate that, do you think?
              • 3192
              #111
              James. I would love to show some pics of it. As I am patent pending I can now disclose and no one can steal it or sell it here. I think it is best I do not show it online yet though.
              Problem is I am only patent pending in the USA and Canada so far. To get international patent pending will cost an additional $5,000 per English speaking country and $8,000 per non English country due to translations etc. Those are cost estimates from my lawyer, so that could change.
              That said I will sit tight for a while longer to see how the process goes. As soon as I am comfortable enough I will post it on this site first. Participation on this forum is the reason I built it and without the members here it never would have been an idea I would have formed.
                Hi Rasputin,
                I look forward to the unveiling of your ingenuity
                • xs650man
                  • Feb 2013
                  • 90
                  • Christchurch, New Zealand
                  #113
                  Not quite an Eleven but its little brother, the 650. For a start the 1.1 is probably twice the weight and a bit more awkward but Im going to give it a go with a beefier crane and modified rig.
                  80 SG
                  93 ST1100 Honda
                  66 split screen VW bus
                    • 3192
                    #114
                    Similar but not the same process mine does. Will it turn into a flat working table, or maybe a spot for your new favorite tool? Will it do a 12HP lawnmower engine? Will it lift horizontally as well as vertically? Just some questions I have to see if I should proceed? Will it accept add on's. Can you use it if not busy changing motors etc. Can you put in a freshly painted engine with it? I hope the powers that be see it my way and I get granted the patent.
                    • jjz28
                      • Apr 2012
                      • 1023
                      • Beckley, W. Va.
                      #115
                      looking great james!
                      77 XS750 2D completely stock
                      • James England
                        • 3039
                        • North of England
                        #116
                        thanks. I'm having a few heeby geebies about the bike running after all this work! I keep consoling myself that it ran when I got it, albeit with one blocked jet in a carb. So, I'm taking it steady, check everything as I do it and mentally preparing myself for teething troubles once it's all up and put back together! Self-confidence issues are the bane of my life occasionally!!!
                          #117
                          James, you do amazing work! I am sure even if it doesn't run perfectly when you get it reassembled, you will have it figured out and running like a dream soon enough!
                          Are you splurging on the stainless exhaust again?
                          • James England
                            • 3039
                            • North of England
                            #118
                            Ah! I feel a bit reassured now, thanks! yes, I think for an accurate rebuild, I'll have to splurge on another replica system. I was thinking of putting an old one, anything, just to get the bike running and then add the expensive one later........
                            I'm on with the wiring loom now...... Pray for me!
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              #119
                              James, if you could get some exhausts available like bearings they would sell well I think. I know I'd buy one.
                              John
                              • James England
                                • 3039
                                • North of England
                                #120
                                John
                                unlike the bearings, the price and shipping costs are horrendously expensive!
