Shim specs
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Shim specs
    Any difference between shim specs on an 81 special and a 78 standard?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    You mean clearances? Yes
    The 78 has a wider exhaust clearance. Different cam.
    Correction........intake is wider.
      Yes and no..... In '80 Yamaha tightened the spec on the intakes by .002" to reduce valvetrain noise. Upside, the motor runs slightly quieter. Downside, the intakes will need adjusting more often. You can run either spec in any motor, you just need to decide if the shorter maintenance interval is worth it for you....
      • Tat2demon
        • Jun 2012
        • 718
        Do either of you have the specs for an 81 special? Going out to do WJWs shims tomorrow but the only books I have are for my E.
        Nate
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
          Intake (since 1980) 0.004-0.006 in.
          (0.11-0.15mm)
          Exhaust (All years) 0.008-0.010 in.
          (0.21-0.25mm)
          • Tat2demon
            • Jun 2012
            • 718
            Thanks guys. Will have to see which way Bill wants to do them. Im all for a little noisier if it means doing it less often.
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
              Originally posted by Tat2demon
              Thanks a lot Phil.
              No problem, specs taken from Clymers and verified to actually be correct.
