Middle drive and final drive filler plug size
  • unicorncomputer
    • Jun 2012
    • 140
    • Southern Vermont
    I need to replace the filler plugs for the middle and final drive. Does anybody know what the size is so I can get them prior to taking them out?
    Thank you,
    Steve
    79 XS1100 SF
    Pretty sure they are the same thread as the oil pan drain plug which is 12MM 1.50 pitch. Maybe someone else can also confirm this. Here is the Yamaha P/N for both mid and final drive filler plugs... 90340-14046-00 PLUG,STRAIGHT SCRW.
    • unicorncomputer
      • Jun 2012
      • 140
      • Southern Vermont
      Thank you for the part numbers, I was actually thinking of replacing them with hex head bolts. What are your thoughts on doing this?
      79 XS1100 SF
        Both my final and middle drive have flanged hex head on them. Ace, Tru-Valu, ect. in their specialty trays have the 'filler' plugs and next tray, the heavy good fitting fiber washers. Use one on the middle drive and double stack them on the final drive(housing has a recess that flanged bolt will hit otherwise).
          • 2104
          Tip:
          Either way you go, hex head or original, reinstall with a little anti-sieze on the threads.
            • 4015
            Nobody is curious as to why the least-wrenched bolts on the bike have to be replaced? i'm curious . . .
              • 2104
              Most likely the bolts that need replaced had been galded and the hex keyed head has been stripped and the bolt has been removed with a chisel.
              I was lucky on my '80G only took a 1' cheater pipe but I didn't strip 'em , haven't tried the SF yet.
                While they might be the least wrenched bolt on some bikes, they should be checked at least annually. Which may match an oil change for some people.
                It is also VERY common that they are stuck and strip the hex head opening round. So, no, I am not surprised they need to be replaced at all.
                  Just remember, make sure you can get the fill plug out before you take the drain plug out!
                    • 4015
                    I took this advice very seriously a few weeks ago. I used my hex sockets, and they broke with ease. Middle drive looked like coffee creamer, final drive looked like new oil.
                    • Cobia
                      • Jul 2007
                      • 1587
                      • Palm Beach County, Fl
                      If your middle drive oil looked like coffee creamer, you've had water intrusion in the MD. Needless to say, not good. I can't imagine how you'd get that water in there.
                      That's why boaters check the lower unit oil of their outboard often, and finding "mayonnaise" color oil points to a bad shaft seal. Running it without replacing the seal leads to transmission failure.
                      1980G Standard, Restored
                      Kerker 4 - 1
                      850 Rear End Mod
                      Automatic CCT
                      1980GH Special, Restored
                      '82 XJ1100 (Sold)
                        I say change the fluid and monitor the level and any changes in color often, at least for a while. I bought a used sx11 and it looked the same way. This thick white gunk did not show on the dipstick. I have done a few middle drive oil changes since and there are no more signs of it. Don't go chasing ghosts if you don't need to!
                          • 4015
                          Hmm. One more thing to worry about now. Thanks fellas.
