As some of you may remember, i was haveing a terrible time with my carbs awhile back. Had them off, and tore down at least 5 times. Yesterday i decided to make sure that my timing was ok. When i opened it up, and checked the timing, the centrifugal seemed ok, but i had no vacumn advance. Glanced over at the unit, and duh, the hose was off of the unit, and allmost through the case. I must have pulled it away on the first time pulling my carbs. Hooked it back up, and pow, the power is back. Still have an upper rpm problem, but i will work on that. MORAL of the story, make sure you check every componet, when searching for the problem.
