Can I just trim my pod filter lip?
  • Briggs&Stratton
    • Mar 2014
    • 47
    • Grand Forks, ND.
    Howdy, can't I just trim the inner rubber lip of my pod filters in the area that would touch the carb bell?
    When I bought my carb boots on amazon, I saw these cheap pods and ordered them, too. My bike already had pods (and without the lip), but they are dirty and I believe one is cracked. I've read here about making stacks using parts of an original airbox, and also T.C.'s method of using PVC couplers. I am just wondering if doing this is necessary if I'd instead trim that rubber lip. I don't have anything against the other methods, but I'd rather keep the pods closer to the carbs, rather than space them outwards and lose room.
    Sorry my first post is a question. I've been lurking several times a day for a few weeks getting lots of info. A good friend of mine is a member here and that's how I found this site. I was planning on doing an intro of sorts first but these filter pods have me perplexed.
    Thanks, Chris
    79 SF
    IG "9mmHeater"
    I don't think trimming the lip is all that possible. You can see in the pic that the filter media is slightly sticking out of the rubber in the lip so you couldn't completely remove the lip. You could bevel the lip, but I don't know if that would completely clear the path for the air to smoothly enter the air jets in the carb intake bells.
    Doeant hurt to try. You could always still add the velocity stacks after trying to trim them.
    • Briggs&Stratton
      • Mar 2014
      • 47
      • Grand Forks, ND.
      The above pic shows an old pod that doesn't have the lip (left) and the new pod with the lip (right). So the protruding filter media you see is actually on the old pod that wouldn't need to be trimmed.
      The new pods' lip looks like it could be trimmed down 1/4+". I'd only trim it in the areas on the bell with air inlets. Btw, the new pods have a taper to the filter. From what I've read here, they could be EMGO but I don't see any markings on them or the box.
      Maybe this pic shows the lip area better. The one on the left is the new one.
      79 SF
      IG "9mmHeater"
        Guess I didn't scroll over and see the other pod...
        Trim off all the excess rubber on the pod and see where that gets you.
        • Briggs&Stratton
          • Mar 2014
          • 47
          • Grand Forks, ND.
          Well that was my question. Trimming that rubber seems too obvious/easy. I thought there was a problem with trimming them, and that would be why everyone makes a stack adapter.
          79 SF
          IG "9mmHeater"
            I don't know if trimming it get enough clearance for the jets, but you can try.
              Hey Chris,
              Look more closely at the new pods, and pull the filter out of the rubber mounts. You'll see the groove that the filter media is mounted to the rubber mount in, and trimming the lip can also remove some of that groove, so that the filter media will be a bit loose...it's not terribly tight to begin with. You'll also want to MARK the outside of the rubber mount so that you can properly position them after the trimming to get the trimmed parts so that they are allowing clearance of the ports. You may need to use some RTV or such to secure the filter elements back into the rubber lips/mounts....to help keep them from spinning as well as preventing leaks.
              • jwhughes3
                • 2798
                • Home of the Alamo
                I tried it on EMGO pods and ruined it.
                John
                '81 XS1100H - "Enterprise"
                • drshankles
                  • Feb 2013
                  • 34
                  • rancho santa margarita, Ca.
                  I have the same pods take the clamps off, pull the boot out of the metal housing, put the boot on your carb mark areas that are blocking the pilot air inlet and cut that section out put your filter pods back on the boots and back on your bike. hope this helps. topcatgr58 has the same solution let me know if u want pics i can pull one off my bike real quick.
                  -1979 XS1100SFCAFE CHOP
                  WEISCO 1196CC KIT
                  SMOOTHED FRAME WELDS
                  YZF-R1 COMPLETE FRONT END
                  DYNATEK 3 OHM COILS
                  MIKUNI RS36 CARBS
                  FIBERGLASS TAIL
                  YAMAHA YZF-R1 REAR SETS
                  LITHIUM BATTERY
                  -1979sf donor bike (sold)
                  -1979sf restored to factory
                  -1986 gsxr750r (sold)
                  Dry clutch
                  4 degree timing plate
                  3 ohm Dynatek coils
                  Dynatek hight output ignition
                  Original 80's 4-1 Yoshimura full exhaust
                  -1994 Ducati 900ss track bike(project)
                  Lots of stuff
                  • Rettic
                    • May 2009
                    • 142
                    • Charlotte, NC
                    Pod Mod
                    I got the same pods, didn't like the lip. I figured it would be best to have the stacks to help out. So I was looking at the stacks from the air filter box and noticed the outer diameter looked about the same as the air pod opening. Well here is what I did:
                    1979 XS 1100SF Serenity
                    1981 XJ650 Midnight - Black Betty
                    Road Dog 4 Life
                      • 2104
                      Good job, nice clean functional install.
                      If you're goin with pods take notes, Rettics bike is the way to do it.
                        Originally posted by Rettic
                        I got the same pods, didn't like the lip. I figured it would be best to have the stacks to help out. So I was looking at the stacks from the air filter box and noticed the outer diameter looked about the same as the air pod opening. - - -
                        Hi Rettic,
                        that looks to me like what you did took far too much careful work and, because you cut up it's rubber parts, you can't go back to using the stock airbox if you change your mind.
                        What I did was buy the oval tapered pods from MikesXS. They don't have the lip and they do have XS stamped into them.
                        • TADracer
                          • 1417
                          • Kenner, Louisiana USA
                          OR, if you want to solve the prob without tearing up your OEM air box you can do this.
                          Get a few strips of 24-ga stainless steel 1" wide. Cut them to the EXACT circumference of the carb bells and clamp them on to extend the carb bell. Mount your filters and the problem is solved. Been running this war for many, many years and never had a filter fall off into the street (which might happen fastening directly to the carb bell).
                          Mike Giroir
                          79 XS-1100 Special
                          • jazzrat2000
                            • Jan 2005
                            • 298
                            • Delray Beach FL
                            Pod extension
                            Just did Rettic's solution, worked great!
                            Dr. Tim Walters
                            Florida Atlantic University
                            The Rats
                            Full Flight Foundation, Inc.
                            "just put the trumpet down and slowly back away..."
                            "owned by a 79 XS1100 Special"
