Don't Stone Me . . .
    • 4015
    So, got the engine all painted and fitted with Euro parts, thanks to James England. Any of you ever carry this engine up the stairs on a dolly by yourself??? Oh my goodness I'll have streaks in my pants for weeks to come! Installed the engine (by myself, a real pain with the middle drive hanging up). Installed TC's fuse box, installed the carbs, etc.
    Got to the exhaust. I had to mentally prepare myself for it, as I always have issues with it. This time it went smoother. Took a break and read the manual for install instructions. Saw that you're supposed to loosen the #2/3 pipes. Go back outside, curse the exhaust system a few times, and then realized I forgot to loosen the #2/3 pipes, lol. #3 goes right in with no issues. #2? Of course there are issues. Studs are just too damn short. Not enough thread for the nut to bite. What do I do to solve my issue? Went downstairs and alternated between sanding dremel attachment, and a half-inch metal drillbit. I countersunk the header flange just enough for the nut to get a bite of thread. I did not remove enough material for any structual issues. It worked great, and was a great stress relief. The bike is turn-key ready. Gotta wait on that clutch arm actuator and the snow to melt, and I can go for a ride.
    What was different between 2 and 3 that 3 would not work? Studs are the same length on both, flange should be the same on both. You took this exhaust off the same bike right?
    Not that I think you did any real damage by counter sinking the nut, but I hope there is more threaded into that nut than just enough to get a bite.
      • 2104
      Jat
      Hi Ian, Are you sure you only have one exhaust gasket in #3 ?
        • 4015
        Hi Fellas- Addressing Don first, I countersunk the flange on the front side where the nut contacts the flange, not the nut. Yes, OEM exhaust. Difference between the two? The #3 had just enough stud showing to get the nuts to bite, the #2 did not, lol. And no, the nut is all the way screwed-in, not just held-on by a bite. And Schming- No double gaskets, all new and very pretty. The only thing I can think of is two things: Scott used different studs on the bike when he had the Mac system on the bike (these seem really short), or during my stud-extraction removal adventure, I drove them into the engine further (not sure how, as that stud was frozen). So, no harm, no foul. I just don't think it's fair I had to do that. I obviously tried to double-nut the stud and pull it out first, and it was very-much stuck. So . .
        • D0wn5h1ft
          • Aug 2013
          • 515
          • Westerly, RI.
          Might have been a good time to replace the exhaust studs!
            So you have one stud on number three that is shorter than all your other studs?
              • 4015
              I started that adventure. But when I ran into the stud that refused to budge, that's when my gut told me to not tinker with things that ain't broke.
              Don- When I look at the studs down the cylinder head, it sure looks like some are longer/shorter than others. May be an illusion though. What I can tell you is that there was a thread/post regarding stud length for Standard/Special. When I pulled my studs and measured for replacement, they were not the same length as posted data.
              • D0wn5h1ft
                • Aug 2013
                • 515
                • Westerly, RI.
                A broken stud is no fun...I had to weld a nut on the end of mine to get it out. Good thing the heat loosened it up!
                • James England
                  • 3039
                  • North of England
                  Ditto...in my XJR1300........ Not to be undertaken lightly.... Here's the warning pic...again the only stud out of eight that would not budge and needed a blob welding onto it after it sheared....
                  • James England
                    • 3039
                    • North of England
                    Nice to hear they all fitted, Ian! You'll notice the difference when riding
