Buell front end swap bearing issues
  • joep7
    • Jun 2013
    • 98
    • Grand Rapids, Mich.
    Trying to get a buell thunderbolt front end on my 79 xs11 frame.
    Buell stem OD is 25.4mm or 1 inch.
    Xs neck top race mount ID is 47mm, lower is 55mm, widths are 11mm and 16mm respectively.
    so my top bearing needs to be
    25.4/47/11
    bottom
    25.4/55/16
    problem is that neither allballsracing or McMaster carries anything in that size.
    im thinking my option may be to either turn the stem down or machine a bushing that fits in the neck....or both.
    Any other thoughts?
    Edit...obviously length is an issue still too but that I have figured out.
    72 Cb900 C
    72 Cb350 Track Bike
    86 Rebel 450
    79 XS11 Standard
    Maybe somehow replace the Buell stem with the XS, the XS is welded in which can be ground off and pressed out, don't know about your Buell stem, JAT
      I'd remachine the Buell stem, or make another one if it's hollow and you can't. The stem should just press out of the lower tree
      Should be a good upgrade, and Buell parts are usually pretty cheap as guys buy them for the Sportster motors then throw away the rest of the bike....
      Post some pics, please!
        25.4/47/11
        bottom
        25.4/55/16
        Hi Joe,
        wanna recheck those bearing dimensions? I cannot believe the XS11 lower headrace bearing cone has a bigger than 2" hole through it.
        Whatever, so long as the XS11 bearings have bigger bores than the Buell's 1" steering stem, you are golden.
        All you need is to shove some aluminum barstock in your lathe and turn up two adapter sleeves.
        Make them about a 0.002" clearance and stick them into the bearings with red loctite.
        • joep7
          • Jun 2013
          • 98
          Well I think I figured out the front end conversion. Took way longer than it should have but putting a Harley front end on a metric bike is a bitch. Ended up making a 30mm OD sleeve to fit common bearing sizes.
          fit perfectly when all was done.
          72 Cb900 C
          72 Cb350 Track Bike
          86 Rebel 450
          79 XS11 Standard
            So that's all that was needed? Just a sleeve over the stem? Piece o' cake....
            It would be nice if you posted the bearing/race numbers....
            • joep7
              • Jun 2013
              • 98
              Top 30/47/12
              Bottom 30/55/17
              From allballsracing
              72 Cb900 C
              72 Cb350 Track Bike
              86 Rebel 450
              79 XS11 Standard
