Headlight Relay malfunction
  • ExcessiveBiker
    • Nov 2006
    • 60
    • Texas
    For about a year, I got an intermittent failure of the of the headlight to come on after starting. This past week the problem has become chronic. I have to repeatedly restart the bike to get the lights to work. This morning, I finally got the headlight on and left for work. Down the road I tried to switch to high beam, and the headlight quit entirely. Pulled over and went through the multiple starting sequence to get it lit again. This is a real pain in bad weather or very dark night. Any info out there?????
    ExcessiveBiker
    81H
    81SH
    80MNS
    76XS750 original owner
    Either take the relay apart and fix it, or bypass it by unplugging and jumping red/yel and blu/blk in the harness plug. Headlight will now come on with the key on. The relay is located under the fuel tank in front above the ign. coils with a 4 wire harness plug.
      Bypassing it is best in my opinion. The light just comes on with the key then.
        • 4015
        I guess I feel dumb for not knowing this. I knew of the RLU bypass (which I know the PO did), but I never knew one of results of the RLU bypass was headlight on when key on. When I considered the HID upgrade, this bothered me, as it is advised to have the headlight off during start-up to reduce wear on the ballast (thus my question of using a '78 on/off switch). So, I'm curious: does the '78 have a RLU? And, if so, can you still switch the headlight off at start-up with the RLU mod on a '78? Also, why is it that you could turn the headlights on/off during riding on a '78 750, but not on a 1100 as you claim?
          The RLU and the headlight relay are two separate things; bypassing one doesn't affect the other. If your RLU has been bypassed but your headlight comes on with the key, that means the relay has been bypassed also...
