I've been emailing with a fellow XSive. He's mentioned exhaust header studs. I believe the engine is out of the frame. So, here's a question, with a poll!
Basically, what do others think about removing the old header studs? The threads are apparently in good condition but, as far as I know, the stud metal can get brittle with all those hot cold cycles over the decades.
I just replaced my XJR studs after 7,000 miles and 9 years. Seven came out easy but the 8th, right behind one of the frame cradle tubes, notorious for being a swine to get out....didn't come out. It sheared. I ended up trying everything known to man to get it out and finally used a small stick welder to weld a bolt onto the stump, having passed the point of no return by trashing the threads with an Irwin wrench. It finally allowed the stud to be removed but, even then, I took 30 minutes of judicious tightening/untightening squirting Plus Gas into the stud, backing it out a bit more etc... I've known threads strip even when a bolt is moving because it jams up again unless done gradually.
Leaving old studs in could mean a snapped stud on a trip, as has been mentioned on this forum, but getting them out can be nerve-wracking and a pain. But, having done all my XJR ones, despite the Stud from Hell (no, not a blue movie), I'm pleased I persevered.
What does everyone think?
