Fuel Petcocks
  • Barlow
    • Jul 2013
    • 7
    • Las Cruces, NM.
    Fuel Petcocks
    I am in the process of restoring my 79 xs1100 special and ran into a question.
    The carbs were off the bike when I got it and I'm not sure how the petcocks hook up to the carbs.
    The tank has a petcock on both sides of it and the petcocks have 2 outlets on them.
    The manual that came with the bike shows a completely different petcock.
    All help appreciated
    79 SF
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    The first question is do You have an 'octopus' .
    It mounts to top of the carbs and has a vac line to the carb boot.
    If not, then dont worry.
    Front petcock out is on/reserve the rear is prime.
    You can cap the prime outlets and run the other ones to each of the carb fuel inlets. (Lower ones. Top ones are carb vents for 78/79 carbs.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • jayel
      • Apr 2012
      • 152
      • Birmingham, Iowa
      the stock dual petcocks are usually marked with a L and R with the prime outlet to the rear
      where are we going, and why are we in this hand basket?
      Iowa the Beautiful Land 1980 XS1100SG
        If your missing the octy and don't intend to reinstall it, look here...
        • Barlow
          • Jul 2013
          • 7
          • Las Cruces, NM.
          Thanks
          OK, I'll see what I can do about connecting the carbs.
          Thanks for the info.
          Happy trails,
          Ben
          79 SF
