lower shock mount removal?
  • Filter
  • lower shock mount removal?
    Hey, has anyone ever tried to remove the lower shock mount on the drive side? Is this a threaded stud? Any ideas welcome. Thanks, Chad.
  • #2
    Hey there Chad,
    All I can tell you is that the parts Fiche doesn't show it as a separate piece/stud, just part of the differential case!? However, the mount is steel, and isn't the diff. case aluminum, so it had to be put there somehow!? Perhaps someone has a trashed one they can experiment on!?
    • #3
      LR Shock Mount
      I have R&R my rear shocks but never had a reason to remove the stud from the rear drive housing. Best I can remember it is a steel stud threaded into an "ear or tab" in the rear drive housing. Like;y secured with "Loctite".
      Ken/Sooke
      78E Ratbyk
      82 FT500 "lilRat"
      • #4
        on my 78E standard it is a stud
        because my nut is tighter
        when i removed my shocks
        the stud came out
        http://home.securespeed.us/~xswilly/
        78E main ride, since birth the "good"
        78E Parts, the "bad" fixing up now
        78E Parts the "ugly" maybe next year
        79F Parts
        80G Parts
        75 DT 400B enduro
        • #5
          Ok, great. Thanks for the quick response guys. Just didnt want to go trying to turn it out if it was welded or something. Thanks again, much appreciated.
          Chad
