Petcock vacuum question
    another option
    Mike's XS has a manual petcock that can replace the XS11 standard valve.
    Petcock - Non Vacuum type 1978-84 XS650
    It's going to work backwards on the right side because they only have left.
    I have an XS650 that I bought new over 30 years ago. It has a vacuum petcock. It has not ever given my trouble. I never let fuel rot in it, either. A proper rebuild should last from now on.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      You can modify your standard petcoks to get an "off" position:
      Tech tip thread: http://www.xs11.com/forum/showthread.php?t=35350
      I've done this to my G and it was so easy. I love having the peace of mind knowing that NO fuel will flow. It's great to have an off position so when the time comes and the vacuum does not shut it off any more, I can switch to off and then pull the tank without spilling any fuel out of a leaky petcock.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
      • LoHo
        • Sep 2002
        • 1342
        • Fresno, CA
        I am usually a big fan of stop-gap measures, but cleaning the petcocks and replacing the innards with the correct kits will solve your problem and make your bike more of a no-brainer. Adding another vacuum device seems like about the same trouble as rebuilding the originals. Adding a cutoff downstream seems like a bandaid that will fail eventually (like when I forget to turn them off). Rebuilt petcocks and good float needles will make the bike safe and reliable and reduce human error.
          • 2104
          Yep yep, I agree 100%, the manual shutoffs, I suggested, downstream of the petcocks would be a bandaid till you get your rebuild kits from George Fix.
          Even the Octy can be restored succesfully, which I'll do once I get to my SF build.
