Cure for tuning bike with mods or BS?
    • 2104
    I'm interested on anyones opinion on this product :
    I may just spring for a kit, for my XV700, when I get to that build.
    These aren't a 'cure', it's more of a 'alternative' method. Semi-popular with the Harley crowd and usually used to chase away flat spots if using a older non-CV type carb. The consensus there is if you're running a CV you don't need or want this.
    Relatively easy to tune on a Harley as there's only one carb, I can see getting a sync on a multi setup might be a problem.
      • 4015
      I think they're cool from what I read in the first paragrapgh, but at 1am, wayyyy too much reading after that, lol. If I were to spend any money on carbs, it would be for newer carbs that are easier to tune, I.e. (ZRX carbs). I honestly don't think the BS34 carbs are that hard to tune as long as the bike is stock and carbs are in good shape. Just patience and maybe common sense. That's all I have to work with, lol. Guys knowing exactly how the carb circuits work etc., have an edge on me, but I'll read those webpages during retirement.
        I was pretty sure I remember a fellow installing them on his bike, his username is 79xs11f and a search for "dial-a-jet" will reveal the threads he's commented on/in. He's done some serious work on his machine, big bore, polished heads/ports, etc., and seems to swear by them, not at them!
        • D0wn5h1ft
          • Aug 2013
          • 515
          • Westerly, RI.
          Wouldn't getting a set of modern Mikuni carbs be just as good of a replacement? It'd be just like living in '78-'81 when these bikes were made as far as finding parts for them would be concerned.
