78 Lift and Duration Specs From Down Under
  • 78 Lift and Duration Specs From Down Under
    Found this handy bit of info from our brother org down under:
    [Camshaft Timing 78 and 80]http://xs1100.com.au/forum/index.php?topic=2005.0[/URL]
    I think the thread is by owner of this 1980 bike putting out 107 hp at the wheels:
    http://youtu.be/B6wr-VJZZHY
    Living to EXcess.
    1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
    He is also a member here. For some reason I can't right now recall his handle though.
      Dan Hodges
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
        Originally posted by WMarshy View Post
        Dan Hodges
        He was referring to the one 'down under".........was the one a couple yrs. back that was shown on the dyno, and he is a member here. Can't remember his forums handle tho.
          Somehow messed up the link but a kindly mod could fix that for me. Or just cut and paste like they did back in the olden days.
          Living to EXcess.
            That'd be Aussixs11G's bike you're talking about.
            Ironically, that thread was discussing his totally stuffed Ivan Tighe cams, so he replaced them with stock 78E cams with slotted sprockets to manipulate the timing. He reckons it was fast before, but now it's an absolute rocket! Can't wait for the next time it gets on the dyno.
              Trying to register for that site is a PITA. They ask you what your favourite motorcycle is as a verification but no combination of Yamaha or xs1100 works. What is the trick question there?
              Living to EXcess.
                Cam Timing
                The cam timing (duration) for these motorcycles are as follows.
                78-79 models
                Intake duration- 247 degrees @ .040 lift & .345 valve lift (event angle 102 degrees)
                Exhaust duration- 247 degrees @ .040 lift & .327 valve lift
                80-82 models
                Intake duration- 235 degrees @ .040 lift & .345 valve lift (event angle 105 degrees)
                Exhaust duration- 235 degrees @ .040 lift & .0345 valve lift
                The early cams are worth 3-4 horsepower more than the late cams.
                  Interesting Dan. So, the cams were the same for 78/79? I hear a lot of people say that the cams were "hotter" on the '78 over the '79, where-as my dad said the only performance difference was timing and carb tuning.
                    Thanks.
                    I noticed that if I set up the bike at TDC with a dial indicator, my cams are at least couple of degrees retarded from looking at the alignment arrows. I'm guessing this comes from chain stretch and losing the base gasket. Also, the exhaust is further retarded from the intake is overlap is reduced. Is it worth machining out the sprocket holes to get it back to stock or is that a waste of time for a few degrees?
                    Exhaust
                    Intake
                    Also, what is the ID of the stock exhaust. The Jardines I have are 1.280 and seem to have a reducing sleeve.
                    I can't help wondering how it would run with the early intake but late exhaust cams. Just curious.
                    Living to EXcess.
                      Wait a minute. I think those cam dots may be able to be re-aligned as part of the cam install. I believe all you have to do is remove your CCT, and put a wrench on your cam one at a time while at TDC to adjust. I think the manual says to only move those cam a hair to re-align, otherwise you may bend a valve. Or worse, wrench slips and u crack the head.
                        And, not sure on ID of header. I do know they are double-walled.
                        • #13
                          And thinking about something, you may very well be off a tooth on the sprocket. If I was you, I'd follow the manual yo the T, regarding cam install.
                          • #14
                            Right now, I'm just set up to measure valve clearance on #1 so only intake and exhaust are in. The chain sets the timing between the cams. No wrenching is going to help that. The only way to change that is to elongate the sprocket holes. Not a big deal to do but worth it? That's out of my pay grade. I'm interested to see how far out Dan thinks those cams are.
                            Living to EXcess.
                            • #15
                              Followed procedure to the T. They are not out. I put them out accidentally while I was monkeying with it before the cam was bolted down so I know how far they look when out by a tooth. ACCT is installed too.
                              Living to EXcess.
