Rear rotor alignment
  • Punisher
    • Aug 2013
    • 26
    • San Marcos, Tx.
    I recently removed the rear wheel to replace the bearings. While removing the wheel I noticed that the rear brake rotor was not aligned in the caliper and was rubbing on the caliper bracket. Viewing the bike from the rear the rotor is rubbing on the right. I am slowly going thru this bike and repairing all the "mods" performed by the previous owner so this is just another "surprise". Has anyone else had this issue or have any idea why this could be happening. Any suggestions on how to resolve it would be greatly appreciated.
    80 XS11 1196 Wiseco kit, balanced crank,
    The most likely suspect is that someone swapped the rear wheels without swapping all of the spacers and brake brace with it.
    The Special models have a 16" rear wheel stock and a one spacer built into the bearing dust cap. The brace that holds the rear caliper and its bracket in place is unique between the Standard and Special models as well.
    On the Standard models, a 17" rear wheel is stock. You will also fin the bearing dust cap, the rear brake caliper bracket and brace, and then another spacer.
    If you have a 17" rear wheel with out the added spacer, or the 16" rear wheel with the added spacer, that could cause the misalignment. It could also be more subtle like the wrong rear brake brace. Again, this is the most likely reason for the misalignment. Or you have the Standard setup and got the spacer in the wrong location.
    • TomB
      • 967
      • Cumbria, UK
      If you're not too fussy about originality just add an extra washer which ever side of brake bracket you need to move over the brake bracket in line with the rotor.
      The caliper will move over in line itself, as you say its the caliper bracket that needs to move over.
      Tom
        You want to be careful about adding washers to move stuff; depending on your combination, you may have to tweak the swingarm and that can make the axle very hard to remove/install.
        Here's the parts needed...
        Special/16" wheel on the left, standard/17" on the right. Sorry for the crummy pic...
        The dust cover/spacer for the special is .3" thicker than the standard spacer, the caliper bracket is different, and the standard has the outer spacer, missing on the Special. The latter spacer is about 1/2" thick.
        • TomB
          • 967
          • Cumbria, UK
          Nah no worries on the washer, theres plenty of slack in the swing arm for a 1mm washer (40 thou to you boys) which is all thats needed to clear the caliper bracket with the rotor.
          Don't get me wrong Steve, I totally agree that the right way is with the correct wheel+spacers combination.
          I use 16 and 17 inch wheels in the same bike depending on which wheel has a good tyre and keep the correct spacers zip tied to each wheel for when I change.
          But in the end it comes down to getting the caliper bracket in line over the rotor without the rotor touching either side, if you havn't got all the OE spacers this can be done easily with washers without wheel alignment issues.
          Tom
          • Punisher
            • Aug 2013
            • 26
            • San Marcos, Tx.
            Rotor Alignment
            Thanks for all the information guys. Like I said before I have been going thru this bike and correcting all the surprises from the previous owner. At this point I am not concerned with originality, mainly safe and functional riding. I have no doubt that the wheels have been changed. It never occurred to me that he would have done such a crappy job, especially on the brake. I am going to start looking for an appropriate washer to get things lined up. Thanks again for all the information.
              I am sure someone here has the correct parts if you could tell us what you need/or what you have.
                • 2104
                . . . I am going to start looking for an appropriate washer to get things lined up. Thanks again for all the information.
                If your bike's a Standard check out the pic on post #8 in this link:
