Hi all. I am new here as well as a new XS11 owner. The guy I bought the bike off of told me about this site and the good information I could get from it.
I just got this bike and did some and had some work done on it. Just had the clutch, intakes redone as well as carb rebuild and timing chain adjusted. It has 30k miles on it. Also, it had the wrong spark plugs in it so those were replaced too. Other minor problem have been repaired as well like shaking tach and speedo and oil leak at the hose connecting to the oil cooler.
I have some other work I need to do on it like repair slow leaking petcocks and replace the exhaust because one header pipe has a small hole in it near the top and another header pipe looks like it was crushed and welded back together.
On to my main question. Other things on the bike were not setup right like the wrong tail lamp bulbs. They were note 1157 bulbs. The turning signals will light up but they won't flash. I have read up on some things in the forums and I have a couple of questions.
Should the front and rear turning signals be using 1157 light bulbs as well. Both the front and rears have to contacts in them and it seems if I read right, that should not be the case. I am wondering if the previous owner bought a front set up signals to put on the back based on what I read earlier. Also the flasher may be bad because it rattles and I don't think that is good. At the local auto parts store they only have the older (ford) style flasher module and it has the same ratings. From what I read on this forum, I should be able to use the 2 connector flasher.
Another question, I can hear the signal canceler click when I turn on the flasher by the signal switch. I ssume this is normal and the canceller won't prevent the signals from flashing.
Sorry to be so long on my first post. It has been some time since my last bike and doing my own repairs on it. Any assistance would be appreciated.
