gas tank on a 78E
  • XS 1100 Rick
    • Nov 2013
    • 39
    • Lethbridge, Alberta, Ca.
    gas tank on a 78E
    My gas tank on my XS1100E has a bit of varnish build up in it but not to bad
    But luckily no rust both of my petcocks were leaking fuel so I am waiting for my rebuilt kits to come in from Georgefix . So before I pull the petcocks off I want to flush out the tank.
    Whats the best and easiest stuff to use to get arid of varnish build up in the tank.
    Thanks
    Rick
    XS11E 1978
    Past Bikes that I owned
    H1 Kawasaki 500 1972
    CB 750K Honda 1978
    CB 750K Honda 1979
    Triumph 500 Daytona 1968
    Triumph 650 Bonny 1969
  • MPittma100
    • Aug 2011
    • 2359
    Varnish Buildup
    I am going to suggest Acetone (if there is no tank liner). If you decide to use this, you will have to exercise extreme care not to get it on your paint as it will remove it quickly. Acetone also dries quickly when exposed to the air, so your tank's interior will be clean and dry when emptied.
    You can actually add the Acetone to the gas and run it through while riding/running. That is the easiest procedure. You could try some of the fuel cleaners that are available at your local auto parts stores.
    One more suggestion is that you use E0 gas (non-ethanol) especially when it sits for long periods of time. E0 is not the easiest gas to find, but it is worth the trouble.
    Check carefully for rust. If there is a significant amount, that is a whole other story.
    Good luck.
    Mike
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      I would think that acetone that is undiluted with gasoline would devour your petcock filter towers... Be careful with that stuff as it will eat plastics as well as paint jobs.
      • Gallaecus
        • May 2011
        • 254
        • East Haven Connecticut
        why not just leave the varnish in there ?
        maybe it will protect the tank from future rust ?
        Steven
        1981 XS 1100 LH
        1979 XS 1100 SF
          That varnish will break down into the gas you put in the tank, and become small particles that can get through the filters and clog up the jets in the carbs, or at least the float needle valves and cause leaky carbs.
          Anything in the tank will eventually get into your engine. If it is not fuel, then it can cause problems.
          • XS 1100 Rick
            • Nov 2013
            • 39
            Thanks for the replies
            I decided to use paint thinner I put a gallon of it in the tank and it seems to be working its loosing it up I go out and swish it around every once in awhile it will take some time buts that aright since I wont be riding anytime soon LoL!!
            Afterwards will rinse it out with hot water and Pine Sol than add 2 pints of Rubbing alcohol to evaporate the water and should be good to go after that.
            Will let you know how this turns out.
            Rick
            XS11E 1978
            CB 750K Honda 1978
            CB 750K Honda 1979
            • scratcher09
              • Dec 2013
              • 19
              • San Antonio, Tex.
              When cleaning out old tanks I use white vinegar and a few spoons of salt. Let it sit a couple days and rinse it out. Works good for surface rust but never tried it for varnish.
              80 LG
                Vinegar will etch the tank! It's an acid. It will get rid of the rust but is not appropriate for the varnish. The paint thinner may work fine. Just get the tank dry as quickly as possible. If the thinner doesn't work, the acetone will. If you have quality paint on your tank, the acetone won't hurt it as long as you remove it right away.
                  • 2104
                  Might be a little late, but for varnish, Berrymans B-12 pourable (or spray), or any good fuel injector cleaner will clean well.
                  I would remove the petcocks, to clean and possibly rebuild, and cap the openings to swish the cleaner around.
                  Also you get a good veiw, of the inside, from the openings.
