Some pictures of my XS11 project
  • justinc1081
    • Apr 2013
    • 61
    • Springfield, MO
    Hey all, i havent posted much but thought i would give you some pics of my project. Acquired bike from father, was sitting for approximately 20 years so lots of items needing resto/replace.
    Hoping to have it road ready by next summer
    First getting it running
    Fixing the pickup coil wires
    Fixed!
    Old busted fuse box
    Improved new style blade fusebox
    Stripping brake calipers
    Painted brake calipers and horns
    Pulled off nasty rims to replace tires and current condition, all tore apart
    80 SG
  • MarkD
    • Jun 2013
    • 488
    • N. Michigan
    Great job so far. jsinc. Looking forward to seeing the progress.
    79 F
    1967 Suzuki X6 Hustler
    1973 Suzuki TM 125
    1979 XS1100 F
    2005 Kaw. Vulcan VN800
    1991 BMW K75
    • MtMark1100
      • Oct 2013
      • 14
      • Kalispell,mt
      Fuse block
      That looks good. Where did you buy the fuse block from?
      78 E
      I'm going to put a Batman Costume in my closet just to screw with myself when I get altzeimers
      • James England
        • 3039
        • North of England
        TC here sells them....... Aka Topcat.
          • 8061
          It looks like you have the right idea. Make it stop and go. The service manual will help guide you to everything that should get your attention. Perhaps you're using it already. Hopefully, we'll see you on that bike at one of the rallies!
          • Prothec
            • Jul 2007
            • 587
            • Fort Myers, FL
            I wish my garage was that tidy
            Website/Blog
              Hey James and MtMark,
              I do resell them, but the ones I provide are 6 slotted, both for those that have the newer model XS11's with the extra separate main fuse aside from the other 4, head, tail, turn, Ign. SO...he acquired his from another source. It's the same style as the ones I sell, but only a 4 slot. I just sold out of my recent batch order, I'll be placing another order today, so if anybody wants to order one, it will be slightly delayed until I receive them from my wholesaler/provider. See the For Sale Forum, Parts, then parts/services by members sticky thread, scroll down to reply #10 for info, photos and such.
              • justinc1081
                • Apr 2013
                • 61
                • Springfield, MO
                got the fuse box on ebay. Just got the old dry rotted tires pulled off rims tonight, lots of cleanup on those rims.. I have a Haynes manual and 2 other manuals i got in PDF form, there is a lot of information i got from this site too
                You all have been a really good resource in helping my restoration!
                80 SG
                • TomB
                  • 967
                  • Cumbria, UK
                  Can I offer a tip on the pick-up wires, they break because the vac advance moves the pick-ups around, and they broke where they did because the wire clip you have not re-used breaks them there, as you have them now they will break next time right at the pick-up coil making them very difficult to repair again.
                  Re-use that second clip and give the wires as much slack as you dare but that they won't get rubbed by the timing disc, strip back the webbed covering, thats where you need the slack, it vastly reduces the localized bending/fatigue breaks in the wires.
                  Originally posted by justinc1081
                  Tom
                  • justinc1081
                    • Apr 2013
                    • 61
                    • Springfield, MO
                    hmm good tip, i have that cover off at the moment anyway, i will put those wires back in that second clip
                    80 SG
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Wire Breakage From Constant Movement
                      Another procedure to help prevent wire breakage is to create a loop in the wires. May be too late for this application, but works very well.
                      Mike
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                      • TomB
                        • 967
                        • Cumbria, UK
                        Mike
                        Yeah Mike, thats what I was trying to say with the "slack", you worded it better. My first XS1100 broke its pick-up wires at 9K miles, I added a big loop by removing the metal clip that holds the wires against the crankcases and the bike has now done 82K without breaking them again.
                        Tom
